Gas Tank sending unit
Discussion in 'Engine/Drivetrain' started by ka6uup, Mar 20, 2017.
  1. ka6uup
    ka6uup Newbie
    I have a 1978 SR5 pickup and the gas gauge just quit.
    The fuel pump is running so I assume the sending unit has gone bad.
    Can the sending unit be replaced separately from the fuel pump?
    And is it likely the gas gauge has gone bad?
    Thanks much,
    Chuck
  2. Steve M Clark
    Steve M Clark Member
    Waynesboro Virginia,Shenandoah Valley
    1980 SR5 short bed
    If it's in the tank they should be separate, follow the gas line back to see .
  3. grassfed
    grassfed Member
    Southern OR
    '76 Hilux
    I have reason to believe the sender in my '76 is going bad. If theres less than a half tank, the gauge shows all the way empty. But it will jump back to full when i fill it up.
  4. fred heath
    It's the sender. Same happened with mine. I was unable to find a replacement so just installed a universal.
  5. Steve M Clark
    1980 SR5 short bed
  6. MtHoodSub
    MtHoodSub Newbie
    Sandy, OR
    1979 sr5
    does anyone know the ohm range of our stock sending units?
