73 hilux won't start
Discussion in 'Engine/Drivetrain' started by Thagreatstallion, Apr 7, 2017.
  1. Thagreatstallion
    Thagreatstallion Newbie
    Hi! My hilux will get fire and fuel but won't start. I replaced the points plugs cap button coil and a new remain carb from holley and it still won't start. It just turns over. Any help or advice would be great thanks!
    Is the timing where it needs to be?
  3. Thagreatstallion
    I can't find anything telling were the timing marks are. I can see little pin on the block but not on the pulley
  4. jetas
    You have the 18R?
  5. Thagreatstallion
    Yea
  6. jetas
  7. fred heath
    Points gapped correctly? A dwell/tach meter will help.
    Are you sure your wires are in the correct firing order?
    Find TDC for cylinder #1. Put your finger over the #1 sparkplug hole. Turn the engine over using the crank pulley bolt. When you start to feel pressure on your thumb your on the compression stroke. Place a plastic drink straw into the plug hole so it rests on top of #1 piston. Continue slowly turning the crank pulley until the straw stops moving upward. This will be TDC for #1 cylinder. Now check your pulley for a notch or index mark.
    TDC should get you started. Also research "static timing". In the old days this was how it was done if you didn't have a timing light.
  8. Thagreatstallion
    Thanks buddy I'll do that. I usually just use the dip stick tho
  9. Thagreatstallion
    I checked the time and it's good. Idk what else it could be
  10. Dennis goeden
    Dennis goeden Enthusiast
    warren ohio
    1973 rn22
    on mine the timing chains were junk , put #1 tdc , pull valve cover and see if pin on cam gear is at 12' oclock and if pointer on the crank pull is at the marks if off need new chains
