2WD V6 rear axle
Discussion in 'Parts and Accessories' started by unclejesse, Jan 23, 2017.
  1. unclejesse
    unclejesse Newbie
    I have a 1989 V6 2WD rear axle for sale. It is an 8" differential, and has if I remember correctly 3.42 gears. Anyway, since it is an 8" diff, that means you can find all sorts of other ratios and lockers for it if you want. This one is complete from drum to drum. It also includes an inspection/fill port on top to make adding fluid easier. I replaced the axle bearings and seals when I had it in my truck. You may want to replace the pinion seal as it appears to be leaking a bit. The axle is in Merced CA, 95340. You would need to pick it up, as I won't ship it. I'd like to get $125 for it.
  2. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    If you were in TX, I'd have offered to trade you some parts and cash for it
  3. unclejesse
    unclejesse Newbie
    still for sale
  4. unclejesse
    unclejesse Newbie
    still for sale
  5. StupidSheet
    StupidSheet Addict
    Canada
    Would you happen to have an auto trans kicking around for that truck or at the very least a torque converter?
