Hey guys, I'm new to this particular forum, because I cant find the info i need Anywhere else on the Web: Can anyone tell me the Color-Code for all of the Wiring that goes into the A & B connectors under the Steering Column (turn signal switch, headlights switch, etc). Or post any pics or Links or anything? I have scoured every single forum I can think of, but I simply cannot find any diagrams, schematics, or anything pertaining to Which colored wire, goes to What particular Accessory, and wheather or not that Wire is Positive (+) or Negative (-). I have owned several of the Haynes repair manuals, but every single question I ever had about my truck, that Manual could not Provide the Answer. So I just simply stopped buying them. I need this info because I had to pull out the Harness when I did the Engine Swap, but Now I'm trying to re-wire everything back up to the Column Controls (Wipers, Signals, Horn, Lights, etc..) My truck is a 1994 Pickup, 22RE, 2-door Single Cab. Thanks for the Help [and I hope I posted this thread in the Right Spot]
Link to a FSM: http://www.toyotaminis.com/forum/threads/toyota-factory-service-manual-link.21369/ If the download doesn't work, i can e-mail you what you need...
This isn't a huge forum with 100's of posts a day but the problem more so is that its kind of an obscure question for someone to know off hand.
2nd plug from left to right on the 2nd pic looks like ign switch wiring. Plug to the right of it is more than likely the turn signals and all that(the one with all the red wires) Honestly just follow the wires up the column towards the wheel and see what they plug in to. Get a better a idea of what exactly youre looking for
