Weber 32/36 question
Discussion in 'Engine/Drivetrain' started by speshalk_82, Apr 20, 2016.
  1. speshalk_82
    speshalk_82 Newbie
    Olympia, WA
    1990 single cab 2wd
    I took the filter off of my carb the other night and noticed the choke wasn't fully opened. The engine was at full operating temp and was running at idle. Is this normal or should/can it be adjusted? I can push them opened but they snap back to this point. Pic included. I checked the next day, and if you set the choke they close all the way like they should but don't ever open any further than this.
  2. 22r
    22r Veteran
    Maui
    Was this a stock carberated 22r? Also it seems in the pic that the choke electrical circuit isnt hooked up?
  3. jetas
    Check if theres power to the choke and if the choke is getting warm.
    Otherwise yes there is an adjustment. Loosen the 3 screws holding the retaining ring around the choke and you can turn it. Small movement gives you alot of movement on the butterfly
  4. Nineteen86
    Nineteen86 Member
    Orange City Fl
    86 xcab
    On my Weber 32/36 carb, I have a wire attached to the screw that's on the white cap on your picture.
  5. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    Check if they open when you use the throttle.
