22re sputter problem
Discussion in 'Engine/Drivetrain' started by Playinwithtoys, Apr 27, 2016.
  1. Playinwithtoys
    Playinwithtoys Member
    Guam
    91 pickup
    ok guys i have a 91 single cab 2x RE and i recently put the batt intake swap and it ran great for a month then i let it sit for two days or so decided to make a store run and when i go through the gears it has like a sputter . Idk thats the closest thing i can get it to my RE sounds like side drafts not getting enough fuel . I need to check the timing again but i did a few notches on the afm adjusted it about 4 clicks so im running lean ish. I just pulled the plugs earlier and cleaned them no bad fouling or any sort i was running rich but not too major .someone know where im going with this?
    could it be sucking air in thru gaps in the piping and clamps?
    Otherwise undo anything unnecessary for the mod and see if it helps.
  3. jblaust
    jblaust Veteran
    Miami, FL
    could be the Air Flow meter
  4. Playinwithtoys
    Guam
    91 pickup
    No i checked all those already and its fine. To me it doesnt seem to be a vacuum leak doesnt seem to be anything internally. I cant figure it out . Sometimes itll sputter like its not getting enough gas then sometimes it sputters like a fouled plug or some ignition issue but i didnt touch anything from the wiring for ignition
  5. jblaust
    jblaust Veteran
    Miami, FL
    AFM can be very temperamental. Could be TPS also.
  6. Playinwithtoys
    Guam
    91 pickup
    Sorry but my tps is dead on where i had it . I been going at this for two days straight , im still as of now trying to diagnose it . Stumpped :brickknock:
  7. 22r
    22r Veteran
    Maui
    Make sure the idle screw on the throttle body is properly sealed with the o ring. If its easy to turn most likely the screws not sealing. Also try giving the throttle body i good cleaning.
  8. Playinwithtoys
    Guam
    91 pickup
    Will do .havent cleaned it thoughroughly since i got it. The idler screw comes undone sometimes by itself . I was told to sync it in then locktite it ? Im not sure any info would be nice
  9. 22r
    22r Veteran
    Maui
    Best way is to change the oring. You can get it at dealerships or on LC engineering. A new oring will hold it enough and prevent it walking out on its own. I dont recomend lock tight. Or anything on the threads. The idle screw adjust the idle and it should never be all the way tightened or all the way out. If im not mistaken on a operating temp 22r the idle should be at 700 RPM for a manual transmission and 750 RPM in gear with an automatic. Give or take 150 Rpms.
  10. Playinwithtoys
    Guam
    91 pickup
    Well i leave the idle screw three and a back a quarter turn if i screw it all the way in . It doesnt make a diff
