Lowering a 1975 Hilix help
Discussion in 'Suspension/Chassis' started by Corza19, Sep 2, 2015.
  1. jetas
    Peter T and twizted1 like this.
  2. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    daaaamn i like that!! looks hella good with the stckers!!
    nice rig
    jetas likes this.
  3. Corza19
    Corza19 Newbie
    Cheers guys :) :D
    Yes the rear is lower.... but not by much. That photo makes it look worse.
    Would probs cut another 1/4 off, but not high priority, really CBF, too much rooting around haha.
    My brother and I like it as is so it will stay for now.
    it might look good from far, but it's far from good looking hahaha. Fair bit off rust in it, heaps off parts/components worn out (we have to replace all the gear linkages next :/) It is still registered (can drive it to workshop, or to servo for fuel...), but really it would be classified as unroadworthy.
    Thanks again :)
    twizted1 likes this.
  4. Cade01
    Cade01 Veteran
    Eugene, OR
    1973 Toyota Hilux
    Here is my '73 with 3 coils cut out up front, 4 inch tapered blocks out back, on stock 14 inch wheels and, 195/75/14 tires...
    Here she is with same suspension, 15x7 wheels, 0 offset, and 205/65/15 tires
  5. jetas
    Heres mine
    3 coils cut
    No bump stops
    3" blocks
    Middle leaf pulled
    No shocks (yet)
    14x7 ~3.5 backspace
    175/70/14
    Front looks a bit lower on this one
    And a butt shot, since this ive added a 1" block from Beefed. Brought the back down enough to sit on the tire
  6. AspireCycle
    AspireCycle Member
    Phoenix, AZ
    1978 Longbed 5 Speed
    according to rockauto, the mightymax and d50 both use moog 2278 springs, so they should be the same.
  7. Cade01
    Cade01 Veteran
    Eugene, OR
    1973 Toyota Hilux
    Well, I was just going on info I was given, maybe they use the same replacements but stock is different, I don't know.
