Stock head gasket thickness?
Discussion in 'Off Topic' started by Litneon, Mar 13, 2016.
  1. Litneon
    Does anyone happen to know the stock head gasket thickness? I'm thinking to switching to an MLS gasket and need some reference.
    Thanks!
  2. TRUCK ACTION
    Measuring over metal portion, 0.058''/7/128''/ 1.38mm, stock gasket!
  3. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    Is that compressed thickness or a new unused gasket?
  4. Litneon
    I have an uncompressed HG, that's roughly what mine measures. But now that you mention it, I don't know if the MLS numbers are closer to a compressed size or not. I didn't want to call LC, because I'm probably not buying from them as they don't have the size I think I need, but I may have to.
  5. TRUCK ACTION
    That is new ,never used!
  6. TRUCK ACTION
    And LC is good with info even if your not buying!
  7. Litneon
    I just don't like to steal their time if I'm not buying from them.
  8. Litneon
    Ok...
    I found the proper info (I think). The stock OE gasket is around .060" uncompressed. The proper MLS gasket for stock thickness is .040" This is due to the fact that the OE gasket compresses quite a bit whereas the MLS will not compress nearly as much.
  9. first80toyota
    Pacific Northwest
    '77 Hilux
    Isn't an MLS gasket multiple layer or metals? (I've never used one..) it would make sense that they don't compress as much since a stock gasket is mainly graphite/composite..
  10. Litneon
    Multi Layer Steel, I believe...
