22re swap
Discussion in 'Engine/Drivetrain' started by Johnno919, Oct 27, 2015.
  1. Johnno919
    Johnno919 Member
    Australia
    22r 91 Xcab
    hey guys im picking up a 22re motor loom ecu package out a corona.
    what will i need to swap it into my current 22r hilux?
    what are little things that i will probally miss? this is my first engine swap i know its not going to smoothly.
  2. Johnno919
    Johnno919 Member
    Australia
    22r 91 Xcab
    someone please?
  3. Erick561
    Erick561 Veteran
    I ship from New London County CT I Price Match
    79 Toyota Hilux 4WD WHEELING DAILY DRIVER
    look on pirate4x4
  4. Ryno5150
    Ryno5150 Member
    Suwanee, GA
    89 2WD reg cab, 85 4Runner
    Only issue will be wiring. Everything else is straight bolt in.
  5. Ryno5150
    Ryno5150 Member
    Suwanee, GA
    Oh, and fuel delivery. I got an EFI tank and EFI fuel lines out of a salvage vehicle. That way I could keep OEM fuel filter, pump, sending unit.
  6. Johnno919
    Johnno919 Member
    Australia
    22r 91 Xcab
    ok cheers i didnt get it cos i figured it was too hard without a donor car so i recon ill build my 22r with side drafts im not good with electrics anyway haha
  7. Micro Machines
    Micro Machines Member
    Portland OR
    92 xcab 22re
    Sounds better then all those wires and sensors to deal with!
  8. sojayota
    sojayota Enthusiast
    Electronics r pretty simple on the 22re only difference is the intake, fuel injectors on intake, and knock sensor. Then all ur accessories. U could always use an inline electric fuel pump and regulator. But sidedrafts are cool ha
  9. Johnno919
    Johnno919 Member
    Australia
    22r 91 Xcab
    im still unsure the sidedrafts are not cheap haha and im unsure and maintenance, i also am keen on efi and maybe a sneaky turbo set up if i could find a donor car so i can see how its all connected
  10. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    throw a weber 38 and a hot cam in that thing and call it a day. Maybe do a custom cat-back exhaust like I did for good sound, without waking up the neighbors when you pull out of the driveway. And by cat-back exhaust, I mean cut off everything after the cat and dump it. Them old cats are perfect mufflers (basically free if you haven't tossed it yet), and give just enough back pressure to hold in your torque.
    At least, that's been my experience. Opening up the exhaust to 2.25" may help depending on the hotness of the cam.
  11. Johnno919
    Johnno919 Member
    Australia
    22r 91 Xcab
    ok will keep that in mind.
    im not sure what type of exhaust its got at the moment i think its a 2-2.5" system
