1991 Turbo propane
Discussion in '1989-1995 Build-Up/Project Threads' started by Hiiamthomas, Aug 17, 2015.
  1. Hiiamthomas
    Hiiamthomas Member
    Northern Nevada
    1991 Toyota Pickup
    This is a start to my build thread of my turbo propane pickup.
    1991 2wd pickup
    1986 22RTE out of a factory turbo truck.
    Here is where we started, dropped it 5inches with blocks and torsions.
    Threw a spool into a V6 8" third, came out of a 1988 Toyota 1ton rear end. 8" with 5 lugs.
    I'll upload some pictures to photo bucket and post soon, the mobile site is only letting me attach one image per post.
  2. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    5"? is that 2" up front and 3" in the back then? i like the way it sits!!
  3. Hiiamthomas
    Hiiamthomas Member
    Northern Nevada
    1991 Toyota Pickup
    It was fun with 5" blocks in the back and the torsions turned down almost all the way with stock bumps. it has a spooled rear with 4.34 gears. but its time to get started with a real build for the pickup that seemed cursed with how many people crashed it and how i ended up with it.
    Here is a pile of parts, from my racing seat to wastegate. 9lb billet flywheel and 1600lbs clutch from LCE
    Getting the chassis ready for some tube work.
  4. Hiiamthomas
    Hiiamthomas Member
    Northern Nevada
    1991 Toyota Pickup
    Time to cut cut cut.
  5. Hiiamthomas
    Hiiamthomas Member
    Northern Nevada
    1991 Toyota Pickup
  6. Hiiamthomas
    Hiiamthomas Member
    Northern Nevada
    1991 Toyota Pickup
    Slowly building a 4link out of left over Ruffstuff parts from my crawler projects.
    Bye bye Horse Collar
    Frenching the tube through the frame with a hole saw, an idea my brother saw on a drag car, and we hole sawed the body so the tube is welded into the body in 4 places on the bottom. We were able to lower the body about 4inches on the frame.
    Can't wait to break out the brake, sheer and bead roller for the floor.
    Tin work will come soon.
  7. jetas
    Frenching that xmember looks good! A lot of work you have done so far.
  8. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    Looks like its about to get serious!! Looking forward to see what you do with it, what are your plans?
  9. Hiiamthomas
    Hiiamthomas Member
    Northern Nevada
    1991 Toyota Pickup
    My plans are to get it as low as possible and as light as possible.
    Id like to compete in the 2016 Virgina City hill climb and visit a few drift tracks in the mean time.
  10. Hiiamthomas
    Hiiamthomas Member
    Northern Nevada
    1991 Toyota Pickup
  11. Hiiamthomas
    Hiiamthomas Member
    Northern Nevada
    1991 Toyota Pickup
  12. Hiiamthomas
    Hiiamthomas Member
    Northern Nevada
    1991 Toyota Pickup
    Checking clearances with windshield in. It's nice to have a rubber one piece seal,
  13. Hiiamthomas
    Hiiamthomas Member
    Northern Nevada
    1991 Toyota Pickup
  14. Hiiamthomas
    Hiiamthomas Member
    Northern Nevada
    1991 Toyota Pickup
  15. Hiiamthomas
    Hiiamthomas Member
    Northern Nevada
    1991 Toyota Pickup
  16. Hiiamthomas
    Hiiamthomas Member
    Northern Nevada
    1991 Toyota Pickup
  17. Hiiamthomas
    Hiiamthomas Member
    Northern Nevada
    1991 Toyota Pickup
  18. Hiiamthomas
    Hiiamthomas Member
    Northern Nevada
    1991 Toyota Pickup
    Shocks are bottomed out there.
  19. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    Wow this build is great. Looking forward to the engine build photo when the time comes. Nice work.
  20. Hiiamthomas
    Hiiamthomas Member
    Northern Nevada
    1991 Toyota Pickup
