over heating
Discussion in 'Engine/Drivetrain' started by beaver50, Aug 12, 2015.
  1. beaver50
    beaver50 Member
    KENTUCKY
    77,TOYOTA STOUT,00,CHEVY, S10
    Im having trouble with my truck getting hot.Its a 77 20R truck.When im driving it gets hot.I can stop and let it idol and it cools back down (the Temp.)Does anybody have ant ideal what it might be?
    Does the fan work? Are you low on coolant?
  3. beaver50
    beaver50 Member
    KENTUCKY
    fan works,plenty of coolant.
  4. jjmartinez1987
    jjmartinez1987 Member
    Glendale, AZ
    1995 Pickup
    maybe bad radiator or water pump?? thermostat??
  5. beaver50
    beaver50 Member
    KENTUCKY
    I changed all 3.thats why im asking.I cant figure it out.
  6. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    Three thoughts (guesses):
    1. make sure you didn't install thermostat upside down?
    2. I once went through three brand new OEM thermostats in a row that were bad; must have been a bad batch. Check (or replace) the thermostat.
    3. Are you using OEM hoses or an aftermarket hose with the wire coil in it? I've read that the wire coils can cause problems and that you should OEM hoses.
  7. jetas
    Did you burp/bleed the cooling systen? After changing those parts?
  8. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    possibly a blocked coolant passage
  9. jjmartinez1987
    Glendale, AZ
    1995 Pickup
    any white smoke through the exhaust???
  10. Busted Knuckles
    Busted Knuckles Member
    Everyone has covered everything I have done and thought of...
    1. Thermostat ( In backwards and testing BEFORE replacing are new thoughts ).
    2. Fan ( You visually see, yes? Broken blades ?)
    3. Blocked radiator - Is the front of the radiator clean of debris, bugs, dirt?
    4. Flush radiator - Flush interior. I used a three day Prestone flush to remove calcium and scale build-up inside the radiator AND engine ports.
    5. Hoses - Might there be a small leak or crack that is evaporating before you see? Any indications of scales on engine from leak?
    6. Radiator Fluid Level - Is the level constant or are you losing fluid? Also check radiator cap. The overflow/anti-freeze fluid reservoir : is it open and spilling out from the engine over heating? If so, what color is the fluid? Clear or rusty?
    7. Blown headgasket - Possible! Just happened to me! Did a full post and got lots of responses. Check oil for water. This is VERY common since the head is aluminum and block is Iron. The different metals head and and block heat and expand at different rates. The gasket between them bears the brunt and breaks. Machinist who shaved my head says he sees this once a week!
    http://www.toyotaminis.com/forum/en...et-back-onto-camshaft-without-removing-20897/
    There's also additive that you can add to radiator that cools the engine up to 20 degrees. I've never used it, but am considering it. That MIGHT address the symptoms of what is happening with your engine. But finding the actual issue is really more important.
    Please respond and share the knowledge and experience.
  11. Busted Knuckles
  12. l2ewind
    l2ewind Member
    Fort Collins Co
    1977 Hilux
    yup!! what busted knuckles said, air pockets are a possibility. Happened to me once on a 99 beetle! Radiator outlet broke clean off, purchased new rad, filled with water to test overheated within 1 minute. Did as Busted said, flushed it one way, than the other, and in a reverse direction, one last time. That did the trick!!!
    l2ewind!
