So I just picked up a set of these wheels for $100. I did a test fit today and the wheels don't seem to sit properly on the front hub. The bolt pattern is the same as the truck and the hub bore is supposedly 66.1 on the Skyline rims but I'm perplexed as to why the don't seat properly. If you guys have any insight it would be much appreciated. Cheers
I have nissan wheel spacers that are hub centric and they will not fit our pickups up front. In the rear they fit because the trucks have the grease caps on the front. There is like 1/4 in of space where they don't sit properly.
I plan on it, but I'm not planning on running the truck during the winter so I may be getting tires early next spring. Did you try removing the dust cap to get the wheel spacers on?
It is not the dust cap that kept it from being flat. Its the hub, there is a lip where the dust cap mounts. I tried cleaning it thinking maybe there was a layer of gunk but it wasnt the case. Try the cheapy autozone spacers. It fixed the problem.
The lip was not on the top of the hub where the dust cap mounts now that i think of it. It was on the lower portion of the hub.
I found a smoking deal on some 1.25" wheel spacers someone decided to not install. Unfortunately even one of the spacers didn't sit properly on one of the front hubs. I had the millwright at my work mill down the inside of the spacer and problem solved. He also milled the outside lip of the spacer flush with the spacer itself, if I didn't do this I would have had the same issue. So the spacers, rims and tires mounted and balanced ran me about $460
