22r tuneup advice?
Discussion in 'Engine/Drivetrain' started by Da_Roach, Jun 1, 2015.
  1. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    Just pickup up an 89 22r (138xxx) 4speed truck for dirt cheap. Looks decent and runs. Came with all history and only work done was oil changes, brakes and tires. It bogs in 2nd and 3rd unless foot in is the floor and lags from a stop. I know the 22re engine but don't know much about carb engines. I going to due plugs, wires, cap and rotor, fuel filter and check timing. Any tips or advice would be great.
  2. White Trash
    It's not going to pull very hard in any gear since it has 3.07's to make up for the lack of 5th gear.
    A solid tuneup and checking the carb & timing settings is a good idea too.
  3. Da_Roach
    NOVA
    Any tips for carb cleaning and tuning? The bogging in gears is what I want to make go away.
  4. HI_state_toyz
    HI_state_toyz Member
    Oahu Hawaii
    89 single cab pick up
    Stock carb? If its stock carb. Id go and get a webber. But for the bogging u might wanna check the pickup line in the gas tank. I had a 82 4x4 4speed pick up line in the tank was pretty clogged
  5. aaron_sk
    aaron_sk Enthusiast
    Tacoma, WA
    '94 Regular cab
    Does the bog get better or worse when the truck warms up?
    How did the plugs look when you changed them?
    How is the fuel pressure?
  6. Da_Roach
    NOVA
    Bogs same cold or hot. Haven't pulled any plugs. Gets a parts order ready. Fuel pressure? How can I check? Like I said still learning the carb world.
  7. Tonka Truck
    Tonka Truck Newbie
    Mullins,S.C.
    '90 Regular cab,SWB 2wd 22r
    I had the same problem with my 22r. Also had the 4speed, and it bogged pretty bad about half throttle in all gears. I changed plugs and set the timing and it made all the difference in the world
  8. aaron_sk
    aaron_sk Enthusiast
    Tacoma, WA
    '94 Regular cab
    Gauge temporarily plumbed inline.
    However from your description of it not being affected by temperature I am thinking ignition timing is the most likely culprit.
  9. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
  10. Da_Roach
    NOVA
  11. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    .... also, maybe run a tank of 91 octane fuel, or dump some SeaFoam in with a full tank. and half a bottle with the engine oil.
    its the first thing i did when i first bought my truck. and had all other fluids flushed as well.
  12. Tonka Truck
    Tonka Truck Newbie
    Mullins,S.C.
    I forgot to mention that I had desmogged my engine. In doing so, I replaced many of the vacuum lines.
  13. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    If you decide to adjust the valves, make sure you follow directions and do them while hot.
    My truck sounded worse than a diesel engine when I did them cold. I was too lazy to go back and re-do them :eek: so I drove around like that for a few years until I had to take my truck in for some other service...
  14. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    .... whats a smog?
    ....I recon its a small hog!
    lmao
    Beverly Hill Billys
