XCab Tool Cubby Sub Enclosure
Discussion in 'Interior/Electronics' started by k5james, May 18, 2015.
  1. k5james
    k5james Newbie
    91 xcab 2wd
    Just thought I'd share some pics of the fiberglass sub enclosure. If you have an XCab and don't mind losing the tool storage space this is the way to go IMHO. This was my first every fiberglass project. It took me a weekend to do it due to me being a novice. I think I could bang another one out in at least half of the time. It was about $100 in material but I have a ton left over and I wasted a ton doing it so I bet that could be cut in half as well. Anyway, here you go...
    Here's the cubby that I used behind the driver...
    Here it is after I stripped it and threw a bit of sound deadener on it...
    Here's the Sundown SD3 8" I used...
  2. k5james
    k5james Newbie
    91 xcab 2wd
    Here's the tape "frame" I made. I used some craft foam to half ass fill in the empty spaces behind the tape...
    Some foil coated with Pam to make the glass easy to get out...
    The "frame" of the enclosure...
    It has a ton of bubbles because like I said, it was my first time ever working with glass.
  3. k5james
    k5james Newbie
    91 xcab 2wd
    Trimmed the "frame" with a multitool and set in the ring for the sub...
    Used an old Under Armour shirt as the base for the bottom and top...
  4. k5james
    k5james Newbie
    91 xcab 2wd
    The finished product...
    With the sub installed...
    It fires down into the cubby. It's a touch too high for the seat to close completely. There's about an inch gap. One of these days I'll pull it out and put a notch so the seat can close completely.
    Overall, I'm really happy with how it turned out and looking in my truck you'd never know I have a subwoofer, which is what I was going for.
  5. jetas
    Looks good.
  6. madstriker
    madstriker Member
    Las Vegas, Nevada
    2008 Toyota Tacoma
    They look great! Good job!
