93/22RE still squealing after replacing all belts
Discussion in 'Engine/Drivetrain' started by RAS671, Apr 27, 2015.
  1. RAS671
    RAS671 Member
    So, the infamous squeals the bugs the heck out of us Mini truckers, or for any druver in general.
    I've replaced all the belts (a/c, ps, & alt.) but the hammer is still squealing, any thoughts? Tension has been set to OE specs.
    Any help is appreciated, Thanks.
  2. Robert m
    Robert m Addict
    Apple Valley, Ca
    '94 single cab, 22re, 5spd
    When does it squeal? cold start, hot start, low rpm, high rpm, only when a hottie is watching, all the damn time?
  3. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    Hahaha! I hate when that happens. That or the brakes squeal.
  4. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    If it is belt slippage and not a bearing. Try cleaning your pulley grooves with carb cleaner/sandpaper/steel wool.
    Worked for me in the past :)
  5. raylcc
    raylcc Addict
    Denver, CO
    Try some belt dressing. Not sure of the actual name of the product, but parts guys should know what you are looking for.
  6. 90DailyDriven
    90DailyDriven Veteran
    New Mexico
    90 standard cab 2wd short bed
    I had a horrible experience with this. I had the splash shield under the truck removed and water and debri kept making it to my belts. Tightening did not work and new belts did the same. I ended up putting the cover back cleaned the pulleys with brake cleaner and a wire brush and that did it.
  7. Gr8KornHolio
    Gr8KornHolio Veteran
    Dallas, TX
    85 regular cab longbed 22R
    I bet that's what's causing my to squeal on occasion. I've always meant to put that back under there. Guess I'll be doing it at next oil change.
  8. moonbeam
    moonbeam Member
    Marietta, Ga.
    94 std cab 2X4
    Strange as it may sound but the idler pulley may be going bad. I thought it was the power steering pump and was about to replace it when I figured it out. Anyways, good luck!
  9. RAS671
    RAS671 Member
    Yeah, after changing out the alternator the belts were still squealing. Not like, a constant squeal, but little squeals here and there when balancing the clutch and gas pedal on an uphill stop light. Changed all the belts and set the tensions right, but still no gold.
    I've got bigger problems now, so will be posting it up in a few. Hope y'all could help
    thanks guys!
