Catylitic converter
Discussion in 'Maintenance/Repair' started by Easyrider1269, Mar 12, 2009.
  1. Easyrider1269
    Easyrider1269 Newbie
    Catylitic converter/Bad exhaust leak. Pls help!
    Hello,
    I have an exhaust leak from somewhere and can't quite pinpoint it. I used a fuel hose and listened to the manifold gasket and collector gasket with no leaks detected. Also, the muffler and exhaust pipe are new, also with no leaks heard. My catylitic converter is shot (very noisy and ceramics all broken up) and I have a new one ordered along with new gaskets. I am also getting very bad fuel economy and rough idling. I cannot hear any exhaust leaking because the CAT rattles so bad. It sounds like little rocks shaking inside a tin can!
    From experience, does this exhaust leak and other problems sound like it's definitely the cat and am I on the right track to remedy the problems? I feel like I'm being gased everytime I drive. The exhaust odor is coming up the side right in through the drivers window.
    Oh, I'm driving a 78 SR5 long bed...
    Thanks!
  2. toy_boy
    toy_boy Addict
    California
    1979 Toyota 4x4
    If your cat is clogged the exhaust pressure will have to find it's way out through some other point.
    When mine would clog on any of my vehicles it would force it's way back, past the exhaust manifold gasket or down pipe gasket. These fumes can and will make it through holes in your firewall and into your cab.
    Needless to say, inhaling these fumes while behind the wheel could be very dangerous.
    Not a healthy thing for the motor to be running for extended periods with a clogged cat either. Problems will arise due to a domino effect of one thing leading to another.
    Been there, done that.
  3. Sound.Vision.Soul
    Sound.Vision.Soul Toyotaholic
    Ottawa, Canada
    93 Pick up I6 Turbo
    The other thing to add to that is as parts of the cat rattle around and cause this build in back pressure it can cause the engine to run rough. And if bad enough even stall!
  4. TRUCK ACTION
    Stainless, small ,flow through cat's are available from LC!:cool:
  5. Easyrider1269
    Thanks for the input. I can't wait to get under there on Monday and swap it out!
  6. FOKAI
    FOKAI Veteran
    SD
    84 truck, 05 4Runner
    Run some seafoam in your truck and you will definitely find your leak.:headbang:
