Back in the saddle...again.
Discussion in '1989-1995 Build-Up/Project Threads' started by Xs5875, Oct 27, 2014.
  1. 1lowSr5
    1lowSr5 Addict
    In the garage
    90' xtra cab Sr5, 2003 taco
    When mine was static I had mine connected still. Just had to adjust it a bit. For low reference I was 1" away from axel on frame. There is a single cable from the e brake handle to about the center of the truck then it has a splitter where the two cables run to each drum brake. Pretty simple setup.
  2. yota4life
    Are you going to coat the inside of the rails with something to keep them from rusting
  3. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    No...I don't think I will be around when 3/16 steel rusts through
    But I have been back in the garage...just messing around. Got the head back and painted the block. Did some mock up because I'm impatient.
  4. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    Wow that looks killer. Great work. Damn that is so clean and fresh
  5. Xs5875
    Xs5875 Addict
    Greenville, Ga
    Well the frame table done it's duty. I took the cab off the frame and then the frame off the table and disassembled my table then made a porch swing out of the 2x4s lol. But the cab mounts were modified to fit this frame with the amount of drop..I set the frame down and then put the cab on...starting to get somewhere now.
  6. 1lowSr5
    1lowSr5 Addict
    In the garage
    Looking good man!!! :waytogo:
  7. stabdd
    stabdd Member
    Victoria, Australia
    2004 Hilux, Single cab Long bed 3RZ-FE (taco)
    x2 !!
    Following this one closely !
    The engine has come up super neat mate!!
  8. Xs5875
    Xs5875 Addict
    Greenville, Ga
    Started the Trans tunnel. It's stock floored obviously. So the Trans tunnel needs to be raised or rebuilt. I'm doing a hybrid as I have no metal forming tools. Besides a rubber hammer a vise and channel lock pliers lol...I program a CMM so angles are 2nd nature to me though lol...here's where I am so far.
  9. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    Looks real good. I personally want to see more on the inside of the rear sliding window, I think that's bitchin'. As for forming metal a lot can be done without actual metal forming tools. All it takes is a little inspiration and perspiration.
  10. Xs5875
    Xs5875 Addict
    Greenville, Ga
    The rear window was rather easy. Not a novice mod. U gotta have big balls to cut out a rear chunk of a perfect cab. This thing runs from the top of the roof to the top of the bed. Placement is crucial. Anything behind the seat u can forget. There will be no storage area. The rear door of the 4runner is arched
    So the bottom section arches the opposite angle of the seats..
  11. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    I don't have any issues cutting and welding sheet-metal I grew up shaving body panels smooth among other things. I figure that's a third gen 4runner liftgate. I see one every so often in the parking lot at my 2nd job (projectionist). I'm wondering if there were any way to just used the section of the liftgate that has the window guides then just use a scissor lift from something that doesn't arch so much. That way you don't lose quite as much space behind the seats (especially for a single cab).
  12. Xs5875
    Xs5875 Addict
    Greenville, Ga
    No sir, the glass is curved. It has to have that arch.
  13. Xs5875
    Xs5875 Addict
    Greenville, Ga
    This evening I will post photos of the installed part. When I first got it I thought Id have to use the wire harness that was in the door, but theres a huge relay in there that wont allow the window to lower if this/that, and wiring for the defrost lines...wiper motor..tag lights...i tried to ohm each wire out, then remove it from the harness. Then I had a lightbulb moment and figured out I could just use a standard relay. (I had the forethought to grab the oem switch out of the console...and guess what, it snaps perfectly into the delete panel beside the dimmer knob on our dash! Who would have known. So I bought some relays and sure enough it works, so to the trash went the factory mega relay and the associated wiring.
    Removing the window frame was a mf'r. There is so much bracing inside that window frame its ridicuous. This 4runner was at the salvage yard because a tree fell on it, come to think of it...the rear section held its shape...this is prob by design in the event of a rollover. Either way..when you think its free, it isnt. Thers prob more metal attaching what we want to what we dont want. But when you get it out, make a template, allow about an inch all the way around. This will take up all available real estate on the rear section of cab..
    The way I cut mine it looks like a factory bend at the top and bottom, the sides match, but the upper corners will need to be blended with additional sheetmetal. You will see that this evening when I post pics. I am unsure of how the raised trans tunnel will affect the windows travel, I guess I could put a battery in there and cycle it. I read a long time ago that a traditional bodied truck wont allow the window to go all the way down. I am stock floored, so Ill know soon. Retain the inside plastic door cover, this will clean it up alot, the raised trans tunnels always look like crap to me so this will be the perfect base to begin the custom console...
    Pics later.
  14. Ryno5150
    Ryno5150 Member
    Suwanee, GA
    89 2WD reg cab, 85 4Runner
    Very interesting. Love all the engineering involved. I really like the rear disc brake conversion. Nice work
  15. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
  16. Xs5875
    Xs5875 Addict
    Greenville, Ga
  17. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    Looks awesome! Have you tested the seats yet?
  18. Xs5875
    Xs5875 Addict
    Greenville, Ga
    I have. 4runner buckets sit just fine. I'm only 5'10 and 165...so I don't need a lot of room lol
  19. silverblazer50
    silverblazer50 Enthusiast
    Thomasville GA
    1994 reg cab
    Looks awesome!
  20. Xs5875
    Xs5875 Addict
    Greenville, Ga
    Just to update this: Im at this point now, and no...the cab does NOT have to be opened up or "channeled" to lay on the rocker, much less the pinch...when using 2x3.My dumba$$ traced the frame out on the bottom of the cab before I removed it then I set out with a sawzall and removed the offending section...now I have to replace it...for nothing.
