BJ Spacers
Discussion in 'Suspension/Chassis' started by redman, Mar 30, 2015.
  1. redman
    redman Enthusiast
    Southcentral PA.
    Just thinking out loud, I know guys use ball joint spacers on 4WD's to lift the front end. I've read where most of these are 1.5" thick. Could a person just flip them like a BJ flip and put them on top of the UCA instead of underneath thus moving the spindle up and giving more drop with less UCA movement ? I guess the bigger question would be How Safe would it be ?:shrug:
  2. 1lowSr5
    1lowSr5 Addict
    In the garage
    90' xtra cab Sr5, 2003 taco
    Jmo, seems kind of dangerous. Might also allow the lower control arm to hit the wheel depending on wheel size.
  3. jetas
    I think some guys have added about .75" of shims for a total 1" drop. I wouldnt do it but to each their own
  4. Gr8KornHolio
    Gr8KornHolio Veteran
    Dallas, TX
    85 regular cab longbed 22R
    I wish I would have kept my old ball joints when I replaced them. Could have cut the actual joint off and the remaining plate would have made a great spacer. Just add the proper length and strength bolts.
