engine temp
Discussion in 'Engine/Drivetrain' started by HI_state_toyz, Mar 14, 2015.
  1. HI_state_toyz
    HI_state_toyz Member
    Oahu Hawaii
    89 single cab pick up
    What is the normal temp? Got a 22re... i think my termostat is no good...after sitting in traffic n driving home my temp gauge hasnt moved it only move bout 1/4 up..heres a pic
  2. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    Your thermostat might be stuck open. I'd get a new one.
  3. kursed
    kursed Enthusiast
    Staunton, VA
    1990 2wd Standard Cab
    Pull the thermostat cold and place it in a pot of boiling water. It should open in the hot water and close when it cools. If not, get a new one.
  4. HI_state_toyz
    Oahu Hawaii
    Yea i need a new one thanks
  5. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    its Race Ready!!
  6. HI_state_toyz
    Oahu Hawaii
    So i changed it still no difference. Is this normal temp?
  7. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    Now I'd look into the temp sending unit.
  8. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    just leave it alone. if it overheats, it overheats. try run it without some coolant and get it hot. if it climbs up to the red, at least u know it works and will work when it actually overheats. fill back up with coolant.
    my buddy's truck is like that, needle will only move about 1/4 of the way even when warm.
  9. FOKAI
    FOKAI Veteran
    SD
    84 truck, 05 4Runner
    I second that. Leave it alone. My old 94 temp guage was always at the same spot as yours. Even on a 100 degree day with a/c on full blast it never reached midway point.
  10. HI_state_toyz
    Oahu Hawaii
    Thanks for all the input yea im just gonna leave it alone fck it lol thanks again
  11. 90DailyDriven
    90DailyDriven Veteran
    New Mexico
    90 standard cab 2wd short bed
    My 90 does this. Changed thermostat and fixed it for about a week then back to the same thing. Been running it like this for 1 year now.
  12. jetas
    Get an aftermarket gauge.
