Looking for good speedometer with trip odometer...
Discussion in 'Interior/Electronics' started by Litneon, Jan 27, 2015.
  1. Litneon
    I need a speedo with a running odometer and trip odometer. My new one doesn't work for some reason.
    The speedo works fine, it's just the odometer that's not working. Unless I have something not wired correctly...
  2. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    I have an electric 4runner dash cluster. I bought it for myself but I'm not sure if I have an electric speedometer or if it runs off of a cable. Is there an easy way to check without pulling the dash stuff? If there is a way to just look under my truck then I'll check. If my truck's got a cable driven speedo I'll sell the all electric one.
  3. Robert m
    Robert m Addict
    Apple Valley, Ca
    '94 single cab, 22re, 5spd
    from what i have read, 91 and before was all cable. 93-95 was electric. 92 was a mix
  4. Tavaresninja
    Tavaresninja Newbie
    Thanks Robert, I've been pondering that myself. Thanks for the information.
  5. TwinTurboTaco
    TwinTurboTaco Enthusiast
    Space
    92 2X
    95 4Runner went back to cable for some weird reason. Not sure if the Pickups did it as well. The 95 4Runner one has a small add on circuit board screwed to the back, but functions the same as a 90-91.
    Lit, you still need a speedo? SR5 style electronic I assume?
