clutch pedal bracket
Discussion in 'Engine/Drivetrain' started by HI_state_toyz, Jan 9, 2015.
  1. HI_state_toyz
    HI_state_toyz Member
    Oahu Hawaii
    89 single cab pick up
    Sup guys.. so my clutch pedal bracket cracked this morning on my 89 2wd 22re
    Dealer said its a discontiued part.. So heres a pic of how i fixed it. Welded the crack n reinforcement... now for some reason my clutch is gtabbing higher.. how do you adjust the clutch? Do I adjust it by the push rod? Lmk please... also do u guys think my reinforcement will work? Also lol where could i get a new one just in case? Lol ebay but only finding used one. Will a older model bracket fit? Like the 84 n up?
  2. 1lowSr5
    1lowSr5 Addict
    In the garage
    90' xtra cab Sr5, 2003 taco
    Had the same problem on my 90. Welded it back together after straitening it out. Mine grabbed higher as well but I liked it better so I left mine. To just it use the threads on the master and you should be good to go.
  3. SloPoke
    SloPoke Member
    corner of 33rd & go to hell
    93 standard cab dx
    Little late but I believe I have a pedal assembly from a 93 4wd in an old truck box in the back yard. If you need it for cheap, let me know.... I'm not looking to make $ but rather just help a fellow Toyota enthusiast out. :waytogo:
