Whaaaat? Read my comment again. If it was level before, then the only way for it to change would be uneven height blocks or uneven adjustments on the torsions. And yes, my truck is really close. I know, I've scaled it. But I'm on air, so it doesn't apply to me in the same fashion. I can change cross weight without affecting it's attitude. It takes the same amount of air on each side to make mine level. That is, unless I want cross weight.
Not at all, could be as simple as the bumpstops are uneven and it's sittin' on one or more. But, I was referring to the "Tacoma lean" earlier...which does not apply, my bad. Your truck is sweet fo sho
