What bolt?
Discussion in 'Suspension/Chassis' started by 1lowSr5, Oct 10, 2014.
  1. 1lowSr5
    1lowSr5 Addict
    In the garage
    90' xtra cab Sr5, 2003 taco
    Going to be using my stock lower control arms and was wondering what bolt size to use to replace where the torsion bar is. Similar if not the same setup as Jason, 93yota, and mikes front setups. Have tried to get ahold of both but since they sold their trucks they don't get on here anymore. Appreciate the help, just want to have the bolt before I disassemble the whole thing.
  2. Litneon
    It's been a while, but I think the stock bolt will continue to do the job. The torsion fits into a key that unbolts separately. Again, going by memory here.... I think the LCA bolt is hidden beneath the torsion bar.
  3. patrickgraven
    patrickgraven Veteran
    Corona CA
    I believe you are correct. From what I remember the bolt head is splined like the
    torsion bar and the bar attachment fits over the bolt.
  4. 1lowSr5
    1lowSr5 Addict
    In the garage
    Appreciate the reply guys. Was going to tackle this today but rain will delay my progress yet again. If it stops today I will try pulling it apart. :waytogo:
  5. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    Yep, you have nothing to worry about. I had that same concern too, the LCA isnt going anywhere, you are good.
    --Mike
