where the heck does this go ?
Discussion in 'Engine/Drivetrain' started by BeamsHilux, Aug 6, 2014.
  1. BeamsHilux
    BeamsHilux Member
    71 Hilux
    Title has my question. Theres a fitting on my air box that goes to something cant figure out where lol. Ill attach a pic
    The little elbow on the bottom side? There is supposed to be a bendable looking metal hose that goes to the heat shield on the factory exhaust manifold
  3. BeamsHilux
    BeamsHilux Member
    71 Hilux
    Ohhh ok. Makes sense now. Brought it to a smog shop today and he said it goes to the stock exhaust manifold. And my manifold didnt have anything like that. Bought the truck without the heat shield. Thanks a lot jetas!
  4. jetas
    No problem. Looks like you have an aftermarket header in there. I think you can pull the intake box and cut that sh;t off and rivet in a flat panel. And make it dissappear
  5. BeamsHilux
    BeamsHilux Member
    71 Hilux
    Yea picked up a hooker header. Maybe if I make that disappear and bring the truck to a different shop they wont know that something is suppose to be there heh. I plan on gettin a weber anyways and eliminating all that garbage.
  6. jetas
    Give it a shot. Most shops around here just take a quick peak and call it done on the visual. Aslong as the sniffer comes up clean your good
  7. BeamsHilux
    BeamsHilux Member
    71 Hilux
    Ah just noticed ur in CA. U runnin a weber or stock carb ?
  8. jetas
    I just picked up a weber. My truck is a 72 second gen hilux. So no smog for me. Still working on getting it running though. The previous owner did a number on the wiring after the 20R swap
  9. BeamsHilux
    BeamsHilux Member
    71 Hilux
    Gotcha. Yea I was lookin at that 73 at the pick n pull and thr 18rc tripped me out. Im guessin they dont produce too much power ?haha they dont seem too popular
  10. jetas
    20R and 22R have more parts available and were around alot longer than the 18R.
  11. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    I saw your other thread about "non-visual smog shops". If you go to a by-the-book smog shop, your truck will fail the visual without that tube (yeah, it's stupid). Smog legal headers will have a tube that goes into the middle of the four header tubes to which you can connect the flapper valve with a tube. Also, I think you can buy (or make) a bolt-on heater tube kit that lets you reconnect that tube. But if your header is smog legal it should already have that.
