Roll pan questions
Discussion in 'Exterior/Body' started by patrickgraven, Jul 19, 2014.
  1. patrickgraven
    patrickgraven Veteran
    Corona CA
    So Im in the process of rebuilding my truck and I was looking for a roll pan. I found one local for a tacoma. My question is would that one work on the 89-95 bed. From what I can tell the rear of the beds look the same, and should roughly the same width. Anyone have an idea if it would work?:shrug:
    I think the tailgates are a direct swap. Obviously they look different but the roll pan might probably be different. Hell just get a grant kustoms rollpan
  3. yota4life
    Grants are pretty cheap last I checked
  4. DTKStout
    DTKStout Member
    Oroville CA
    Too many to list.
    The rollpans are the same width but the height and profile are different. You can adjust the profile at each end to match the older bed but the center will still retain the tacoma profile. I would just spend the extra cash and buy a pan that is built for the truck.
  5. patrickgraven
    Corona CA
    Ok thanks. It was local and a sir Michaels one and was cheap. I will look for one for my bed.
  6. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    Ebay has them. Some are just under $100 with license plate box and free shipping.
  7. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    Honestly, I bought mine from Grant I think but it would've been alot cheaper and very little more work to make your own . Just my .02. Ended up having to fit it quite a bit for it to be perfect and need a couple small pieces of filler plate where it didnt match up perfectly.
