My toy
Discussion in '1989-1995 Build-Up/Project Threads' started by yotaman95, Feb 11, 2012.
  1. yotaman95
    yotaman95 Enthusiast
    Cottonwood Heights Utah
    1995 single cab
    Been pretty busy with my Lego lately, after i changed the heater core i changed the bulbs behind the dash to L.e.d.s [​IMG]
    HiLuxDreams and roo13s like this.
  2. yotaman95
    1995 single cab
    I got a Tonneau cover and hercilined the top. I also painted the center caps carribian blue and brake drums black.[​IMG]
  3. yotaman95
    1995 single cab
    So out here is SLC Ut everyone and their dawg drives a subaru, I am friends with a few of them tho. One of them hooked me up with a new captains chair. Bride [​IMG] I just wish it wasnt red but ill prob get it recovered down the line. enjoy dudes!
  4. tyme_fo_play
    tyme_fo_play Addict
    94 BLOCK HAWAII
    MY PRIDE MY JOY MY TOY!
    damnnn! those seats look sickkk! IMO. lol how much you got them for?
  5. white93turbotruck
    white93turbotruck Enthusiast
    you have one hell of a sick truck man!!!
  6. yotaman95
    1995 single cab
    Thanks guys! I am pretty stoked with it.
  7. AssYriaNrocKer
    AssYriaNrocKer Enthusiast
    Silver Lake WI
    1994 PU
    76k?????? shiza!
    -RONI-
    :headbang:
  8. yotaman95
    1995 single cab
    Yea buddy!
  9. yotaman95
    1995 single cab
    Whole front and rear suspension is on its way! Yep I am pretty stoked to say the least.
  10. Blitz
    Blitz Enthusiast
    Georgia!!
    It's not a Toyota
    I like what's going on with this one.
  11. standardbyker88
    Looks really good. How do you like the new seat? Is it a solid angle or does it recline? I want something more racey for my hilux, the 77 corolla buckets i have are toast. I love the halo shot. Are they LED halos? I used to have H4s with a 194 socket and I had purple LEDs in them. Would leave those on all night. So I could see my truck real easy lol. The corners had the same bulbs but not seperate wiring so at night it was just the heads. Heres a pic
  12. yotaman95
    1995 single cab
    Na they are as close as you can get tho they go all the way around my headlight with a blue l.e.d. on the top and bottom. Yes the seat reclines and slides it is prime as hell. With my Nitro 2 drop shocks, spindles and sway bar lets just say around corners you dont move, unless the rear end slides haha. Just want the front end a bit lower. Any suggestions fellas?
  13. yotaman95
    1995 single cab
    Is anyone on here rocking XXR's? If so what size? Do you have rubbing issues?
  14. DugsulOrDie
    DugsulOrDie Member
    Honolulu, HI
    '92 SingleCab
    What kind of fitment are you looking for? And what drop are you currently? I've been messing with the fitment on our style trucks and tire sizes for a while now so I kinda know what fits and now lol.
  15. yotaman95
    1995 single cab
    Alright I wanna run an 18 or 17 its gunna be a 5 spoke with lip. I am on 4 in. blocks in the rear, and have spindles, drop shocks, ball joint flip and re-keyed my torsions. Just curious on how wide i can go?
    I have access to a fender roller that i plan on using this summer as well.
  16. DugsulOrDie
    DugsulOrDie Member
    Honolulu, HI
    '92 SingleCab
    What width,offset, and tire size were you planning on going? Theres no problem in the rear if you're only 4" drop and tucking. I'm at 8" and still don't rub when I had my 9s in the rear and my offset was at +5. If you're planning on poking out the rears with a 9, go +7 offset i think and for a 10 maybe 0. As far as the fronts, I have 4x4 fenders so i can go just as wide in the rears or a little less. You're gonna have to remove the fender lining, grind off excess bolts in the fender well so it doesnt eat up your tires and pound out the areas where tire is making contact. There's gonna be a railing where the fender lining used to mount up, you're gonna have to cut that off too so it doesn't chew your tires out. Oh yeah and in the rears, if you do decide to go 17x10, grab an offset +25 or lower because it'll rub the leaf spring plate. 18s doesn't have that problem but bigger the rim higher off the ground and more you gotta drop the truck to compensate.
  17. yotaman95
    1995 single cab
    Alright I feel ya! Thanks for the info pal!
  18. Beefed Taco
    Beefed Taco Addict
    Sweet little truck! :waytogo:
  19. 52mini80
    52mini80 Newbie
    Denver
    1990 2wd
    So you have the regular bumper with a 92-95 valance? does that just bolt up!? sweet truck! love the white.
  20. yotaman95
    1995 single cab
    Yes sir it came with my truck when i bought it stock with 64k miles. Yes they are 92-95 and yes they will bolt right up.
