76 20R rattle
Discussion in 'Engine/Drivetrain' started by vfrvin, Mar 4, 2014.
  1. vfrvin
    vfrvin Newbie
    Seattle
    76 truck
    Hey, so I thought the throw-out bearing was bad and as it turns out- not. So there is a noticeable rattle that increases with throttle... lifters? valves? it seems like a lighter almost tinny sound maybe popcan like, not the deep knocking of death in the lower end. like I said... sounds like a throw-out bearing... runs fine. starts right up. totally stock truck. 200,000mi. (od says 92,576, guessing 192,xxx) Suggestions?
  2. vfrvin
    vfrvin Newbie
    Seattle
    76 truck
    My friend had told me to not worry about the timing chain- but does that sound like a symptom?
  3. jetas
    If for some reason it has enough slack or a guide broke its probably slapping around. My old nissan had an annoying tick sold it before i got to fix it. Pull the valve cover and see if thats the problem
  4. standardbyker88
    Yup pull the valve cover. Use ain't flat screw driver to reach down and apply tension to the chain. If its floppy plan to swap it out. Also look for loose valves. You should actually set them, sometimes its just a noisy valve.
    Could also be an exhaust gasket near the motor ticking in a similar sound.
  5. eighty_D
    eighty_D Member
    Fairbanks, AK
    '79 SR5 2wd lwb
    Check/set the valve lash first. Also mine had a "tick" when I got it, the exhaust manifold gasket was toasted from a leaking vc gasket
  6. vfrvin
    vfrvin Newbie
    Seattle
    76 truck
    thanks! guess i'll be bustin knuckles this weekend....
  7. vfrvin
    vfrvin Newbie
    Seattle
    76 truck
    So the rattle turned out to be a large hole in my exhaust manifold, pushing against the aluminum cover. Anybody have a non emissions 20R exhaust manifold for a good price? My plan is to geta header soon, but I'm not in a position to change the whole exhaust right now... thanks for the help!
