static drop..... how low are you?
Discussion in 'Suspension/Chassis' started by SD YOTA, Dec 25, 2008.
  1. standardbyker88
    I recently picked up an 88 standard cab shortbed. Has a 2" body drop, cranked torsions and flipped upside down leafs mounted to top of axle. I put a set of 15s on to see how it sat, and here it was.
    I am doing a prerunner project so it already has a bit of a lift. I flippes the springs to be arched and took the torsions all the way up. Debating a build thread here since it is a 2wd Toyota but not the norm here. I'm not on 4wd sites,
    I just love it here lol
  2. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    F it do a build thread.
    I wonder how it rode with flipped leafs. Did you snap a pic of how it was set up?
  3. standardbyker88
    I probably will throw a thread up. And I don't know how it rode but I have before and after pics ill post eventually.
  4. Impassta405
    Impassta405 Newbie
    Edmond, Oklahoma
    1985 standard
    Here is where mine is at right now. The shocks are bottoming out bad, they only have about 1/2 inch travel if that.
  5. LilRed93
    LilRed93 Addict
    Spanish Fork, UT
    1993 Pickup
    Full ball joint flip and 3" blocks. Still need to do spacers on the ball joints. :waytogo:
  6. raylcc
    raylcc Addict
    Denver, CO
    Do you have a pic of the dash? Is it custom or from another vehicle? :drool:
  7. burquescraper
    burquescraper Member
    Charleston sc
    87 xcab 91 rx7 totaled:(
    so just put new 18s on my truck gotta drop it back down now but im already running 5 in blocks in the rear how much do you think i can pull out of removing the center leaf in the back. if not how much can you pull out of flipping the rear leafs and how much of a pain is it. i know the front torsions can be played with quite a bit all i did before was spindles and a bj flip. haven't even cut the bumpstops yet. im not afraid to cut the wheel wells just havent had a reason.... yet will have pics up soon working on a temp paintjob now tired of it being 5 colors
  8. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    You are going to need to c notch the frame in order to pull the center leafs since you are already on 5 inch blocks.
  9. burquescraper
    Charleston sc
    damn hoping i could get another couple inches before i had to do that guess ill have to suffer not scraping everything till i can afford it. at least the paint job looks decent its in the gallery cuz photobucket wasnt wanting to work
  10. Gr8KornHolio
    Gr8KornHolio Veteran
    Dallas, TX
    85 regular cab longbed 22R
    Speaking of scraping everything, I hit a small dip while changing lanes this morning and scraped on the little lane reflectors. :headbang:
    twizted1 likes this.
  11. burquescraper
    Charleston sc
    beautiful man gotta love when those lil suckers go flying
  12. FiretruckYoda
    FiretruckYoda Member
    SoCal
    '86 reg. cab
    4" blocks in the back. Cranked torsions and BJ flip in the front (no washers).
    15" rims. Forgot the tire sizes, but I believe 205-65 rear, and 195-60 front.
  13. Gr8KornHolio
    Dallas, TX
    Sweet ride Firetruck. I know I'm already on this thread, but had to post after another one like mine.
    BJ flip, LCA, Spindles up front. Belltech leafs and custom streetaco blocks out back.
  14. wormsanity2385
    wormsanity2385 Newbie
    Canton NC
    87 Toyota 2wd pickup
    It rides pretty low... swapped the wheels today for mustang gt wheels
    NOT SURE YET ON HOW TO POST A PIC ON A THREAD?!?!?! NEW TO THE SITE!!!! SOMEONE PLZ HELP SO I DONT HAVE TO POST LINKS!!!!
  15. burquescraper
    Charleston sc
    [​IMG][/URL]
    Haven't dropped the back but 2 inches should be lower when I put the 5in blocks on
  16. Cade01
    Cade01 Veteran
    Eugene, OR
    1973 Toyota Hilux
    My '73 has 4 inch blocks out back, 3.5 coils cut up front with the rubber coil isolators removed, and I believe I'm on 205/60/15s.
    twizted1 and KERTWOOD like this.
  17. Project Mini
    Project Mini Newbie
    Whats up bro where did you buy ur tail lights from? I just picked up an all stock virgin 89 yota pick up white like yours any tips
  18. Dark
    Dark Newbie
    Cranked torsion and 2 inch block rear
  19. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    I had those same rims years ago. Drop is nice, have any other plans?
    Not sure if its just me, but your 2nd pic is upside down.
  20. Dark
    Dark Newbie
    Yah sorry about that upside down pic...
    Still deciding if static or bags...
    And the cheapest way too..lol
