Leslee, the truck that will!
Discussion in '1976-1983 Build-Up/Project Threads' started by Aircooled, Sep 26, 2013.
  1. standardbyker88
    Slick bike! Props on the indoor storage, I always planned the same.
    I have a factory dash panel that goes under the center heater vent an holds 2 2" gauges. It's tan. Let me know if ya want it. Cover shipping and its yours.
    And good idea foaming the flapper doors and stuff to make if direct to where it should. Makes me wanna fix my heater. Just needs a 195 thermostat instead of the 180. I have a huge aluminum radiator and its over cooling in the cold temps lol
  2. Aircooled
    Aircooled Member
    Kansas
    81 Pickup, 83 Pickup
    Thanks! I love it, it's my first bike.
    I thought that looked pretty empty. I'll have to google some images see what it looks like but yea I would be interested.
    Yea works perfect only thing was it was leaking after I installed everything so I had to rip everything back out and found it it was just because I didnt tighten the clamp that connect to the heater core :verdict_in: Definitely worth ripping out though to do so. Only thing I would do different is actually make sure all the old foam is off with a grinder or sand paper maybe a solvent. All I did was rub most of it off and peel but the foam still sticks.
  3. Aircooled
    Aircooled Member
    Kansas
    Update: Forgot to tighten clamp that connects heater core to pipe had to rip it back out and tighten it. Removed the smog pumped and got to use my bed for the second time. First being picking up firewood and today used to move my mothers dining table. here are some pictures. Sorry about my engine baby cleanliness is definitely not a priority of mine right now :shrug: Got to drive a friends Silverado too. Makes me want a tundra
    Next up is to order the block off plates for emission system and then de-smog and a tune up.
  4. riceratyota
    riceratyota Veteran
    backwoods oklahoma
    which one 77/78/79/81[r.i.p]82 sbrc driftbox, and a CeliLux/current daily= 79 sbrc [lil' blue]
    what I want to know is how did you steal my truck and do all these things and then change it back and get it back to me without me noticing
  5. Aircooled
    Aircooled Member
    Kansas
  6. Beefed Taco
    Beefed Taco Addict
    Sweet little truck. Love seeing the progress, thanks for sharing. I also like your username and avatar too. :waytogo:
  7. Aircooled
    Aircooled Member
    Kansas
    hahaha thanks! I'm a vw, porsche guy at heart. Also into old school motos. Thats where I got my username from.
  8. Aircooled
    Aircooled Member
    Kansas
    Alright, long week and woman problems :looney: But I have done the emissions delete. Smog pump, air injection manifold, pair/reed valve whatever it is, plugged off the EGR. I just received the block off plates yesterday, I will put those on tomorrow. I replaced the vaccum hoses. I haven't decided if I'm going to remove the charcoal canister yet. I might just take it out and unclog it. Only vacuum hoses I have is to the vacuum advance and charcoal canister. I'll remove the egr tomorrow night and try and detail the bay with the help of a six pack and I'll post pictures!
    Btw if you havent already delete your emissions.. do it!! The truck runs a lot smoother now. :waytogo::waytogo:
  9. Aircooled
    Aircooled Member
    Kansas
    Been a awhile. Haven't really done much except kept it running. Did a tune up and oil change. Need to get my moto finished and then I'll start working on this again. Can't wait to start working on it. Seems like these truck never stop running.
  10. Aircooled
    Aircooled Member
    Kansas
    Been awhile but finally got to working on the truck. Picked up a 83 pickup flat bed with a rebuilt 22r and 5 speed for 225 bucks :headbang:Grabbed a bunch of stuff from it. Pics coming soon.
  11. Aircooled
    Aircooled Member
    Kansas
    This truck has been a struggle but as it sits. It now has a 20r with a weber 32/36 and a 5 speed. Surviving in this freezing midwest weather.
  12. disturbio
    disturbio Enthusiast
    Yuma AZ
    1972 Yota HiLux
    Nice lil rig
