flywheel fail...
Discussion in 'Engine/Drivetrain' started by justaguy, Feb 2, 2014.
  1. justaguy
    justaguy Member
    75 hilux, 84 xtra cab, 86 1 ton, 87 xtra cab 4x4
    So, my flywheel decided to shear the bolts connecting it to the crankshaft... Anyone have a 22r or 22re with 5 speed? She's my only rig, and I need something asap. Any help would be appreciated.
  2. standardbyker88
    A machine shop should be able to get the broken bolts out cheap. I broke two of the six holding my flywheel to clutch. Seems to still work lol
  3. justaguy
    justaguy Member
    The holes are pretty warbled out, and would need both the crank and flywheel surfaced as well, tried to post a pic but it's a pain from my phone. If i'm gonna go through all that effort I'll just put a new motor/Trans. Saves time. Gotta get to work on Monday
  4. standardbyker88
    You could also swap flywheel and crank. 20 and 22r have the same crank. Might be a cheaper fix. But a running donor motor is the easiest swap with how simple these motors come out. One afternoon could have it fixed.
  5. justaguy
    justaguy Member
    I'm already halfway out lol. I may have a 22re sourced out though
  6. justaguy
    justaguy Member
    So, the 22re isn't going to work out. Incomplete/wrong harness and couldn't locate a carb intake. Good news is I got aholdof a 22r with 0 miles. Should be up and running again tomorrow. If any anyone is interested the re will be for sale. more info later. Also I'll get around to a build thread if I can get some more internet and hop on my computer.
  7. standardbyker88
    Good deal. A carbed 22r is plenty. Works great for my 78.
  8. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    Wish I woulda known, I have an extra 22r intake you could've had..
  9. standardbyker88
    I never keep them personally. I only run 20R heads and intakes. Way better flow.
