No ignition unles I run a hot wire to the dash
Discussion in 'Interior/Electronics' started by Chucky, Dec 19, 2013.
  1. Chucky
    Chucky Enthusiast
    Southern Louisiana
    88 pickup reg cab,82 sr5 long bed,93 reg cab sr5
    All of a sudden the next morning I I jump in my truck to start it and I have no power to the dash or wouldn't turn over.i charged the battery and tested good.. Now I ran a hot wire to the key switch and everything works now.. 2days after my battery and alternater died... Is there any relay or Somthing to replace that powers the electrical components and ignition... I have an 82 sr5.
  2. minitruck88
    minitruck88 Newbie
    san jose , California
    1988 2wd pick-up
    there's a lot of fuses and relays that you've bypassed by running a hot wire , you should start by checking all your fuses ether with a test light or pulling each fuse . But it almost sounds like you may have shorted something out
  3. Chucky
    Chucky Enthusiast
    Southern Louisiana
    Thanks I checked all fuses all seems good where is the voltage regulated is it built in the alternator?
    Any other ignition relay that I have to look through?
