tighter steering
Discussion in 'Suspension/Chassis' started by 87pickup, Dec 10, 2013.
  1. 87pickup
    87pickup Member
    ontario ca
    87 single cab short bed
    Like the title says what can I do to get a little bit tighter feel on the steering?
  2. topcop182
    topcop182 Addict
    Colorado Springs Colorado
    1993 single cab 2wd
    Bushings will help, marginally. I want the same thing, but you have to keep in mind these trucks will never steer or feel like a BMW etc. :-(
  3. Litneon
    Suspension bushings, rod ends, and lower profile tires just to name a few...
  4. SD YOTA
    check all your tie rod ends, idler arm, drop link for starters. replace if they feel lose at all. LCA, UCA bushings, radius rod bushings, upper, lower ball joints should all be checked.
  5. White Trash
    Adjust the backlash in the steering box. My 90 has manual steering and it was a bit loose when I got it. I took about half a turn to snug it up and now it's perfect. A word of caution though if you go too far you'll lose return to enter and the steering will be difficult.
    I have urethane bushings going in soon to make it even better.
  6. 87pickup
    87pickup Member
    ontario ca
    How do u do that?
  7. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    sign of a worn gearbox. Mine's bad too. It tightens up the middle section but not the outer 2/3. Not really fixing it and only half the adjustment. DON'T OVERTIGHTEN it or you'll really chew up the gears and bearings.
  8. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    This is why I wana put a power rack in my truck. Has any one done that yet?
  9. 87pickup
    87pickup Member
    ontario ca
    So I tighten this screw but not too much right?
  10. White Trash
    Hold the center adjuster screw while you back the lock nut off a turn or three. Then turn the adjuster screw in a little at a time and wiggle the steering wheel back and forth a bit to get the sector shaft seated in it's new position. Then adjust a bit as necessary. Once you've turned it in enough there will be no slop but the steering will still be easy to turn. If you go too far there will be no slack but the steering will also be hard to turn.
  11. NashMan
    NashMan Toyotaholic
    94 2wd
    I think I am going to swap to power rack soon I have setup in mid that should work
    just have to swap the alt to were the ac is so it's easyer to run steering linkage
  12. 87pickup
    87pickup Member
    ontario ca
    Thank you guys steering feels way better
