Fuel pump is not sending fuel to the carb
Discussion in 'Maintenance/Repair' started by Killerkoff, Dec 2, 2013.
  1. Killerkoff
    Killerkoff Newbie
    Olympia
    1976 pickup
    Not getting the fuel
    Cranked and crank and crank
    It's just not working
    Any ideas????:shrug:
  2. standardbyker88
    What year? Electric pump or mechanical? Stock carb or weber? It could be a bad fuel pump relay. The pumps themselves wear out. I have done a few bed removals to swap pumps. Easy task with a helper of engine hoist. I always pull my bed alone with a hoist. Good luck with it and welcome to the site.
  3. Killerkoff
    Killerkoff Newbie
    Olympia
    1976 pickup
    Thanks for welcoming me to the site!!
    It's an 77 an it has an electric fuel pump in the tank
    Stock carb. The fuel filter does not have any gas in it
    I just put a new pump in. I put 5gal in the tank and
    Have cranked it over way too many times!! :)
    Was thinking that it somehow still has air in line?
    Or maybe it needs to be full?
    Also the salvage yard tested it before they sent it.
    Good news is that fuel gauge works now!
  4. standardbyker88
    It sounds like your pump isn't getting power. The relay is on the bottom of the steering column above the brake pedal. The wiring itself could also have corrosion at the firewall plug. I would check those next. The relay is out of production so you'd have to wire a universal relay on with new connectors. Not too tough. I have fought similar issues with my 78. You should have enough gas in the tank, and it would push any air through with fuel behind it.
    Could also be the little check valve right after the pump in the tank. If it lets the flow out early it won't make it down the lines.
  5. standardbyker88
    I just did mine last week so its fresh in my head. Check valve is the brown t fitting just after the pump.
  6. Killerkoff
    Killerkoff Newbie
    Olympia
    1976 pickup
    Awesome thanks for the help! Funny thing is the gas gauge didn't work on
    The old sending unit (small thin windings toast) and now the gauge works but not the pump! LOL!
    Well if it is blow and it sounds like it is I can swap them out
    Thanks again!
  7. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    Mine had the relay go out and all I did was cut the wires and put a toggle switch between the power wire(cant remember what color)and the black/red wire for the pump.
    Works perfectly now! I have no idea what the other wires from the relay are for but I didn't hook them to anything and haven't had any problems..
  8. standardbyker88
    I have put a jumper wire into my relay plug before to bypass it too. Until I found another working relay at a junk yard. If I have anymore I will send you one. Ill look in my parts stash. Or a toggle can be ran.
  9. Killerkoff
    Killerkoff Newbie
    Olympia
    1976 pickup
    Awesome!
    I'll try the swap and see what happens
    This time I'll make sure it works before I put it back in!
    Also I'll make note of the relay if it still doesn't work
  10. Killerkoff
    Killerkoff Newbie
    Olympia
    1976 pickup
    Also I noticed that the pump on the pic looks
    Brand new is it? If it is where can I get one?
  11. first80toyota
    Pacific Northwest
    '77 Hilux
    I got mine from autozone.. If I remember correctly it was like $77 for it and a new strainer..
  12. standardbyker88
    Yup. All the parts stores have them. It's the second one ive put in. First ones strainer fell apart and got into the pump. Replacement parts quality has gone to hell these days. Anyways, yeah, they're available.
  13. Killerkoff
    Killerkoff Newbie
    Olympia
    1976 pickup
    Cool I'll just buy a new one instead of chancing the old one
    Thanks for the info!
  14. Killerkoff
    Killerkoff Newbie
    Olympia
    1976 pickup
    Ok so I got the pump an I'm not 100% sure what connector
    Goes where? I didn't take notice
