motor swap???
Discussion in 'Engine/Drivetrain' started by 87pickup, Dec 2, 2013.
  1. 87pickup
    87pickup Member
    ontario ca
    87 single cab short bed
    I have a 93 single cab short bed and my cousin wants to sell me his full vq35 swap for only 1150 is it worth putting in our trucks if so what has to be done?
  2. standardbyker88
    That's the Nissan 300zx motor correct? Not much info on the swap but id say do it. I always like big crazy motor swaps. Maybe search around the jap boards. Over there it's common to put sports car engines into their trucks due to how easy parts are to come by.
  3. 87pickup
    87pickup Member
    ontario ca
    The motor is from a 06/07 350z I believe ...the biggest issue I think ill have is fitment ????
  4. standardbyker88
    Anything will fit. These engine bays are pretty open. I've seen inline 6s with turbos, various small blocks, even a few big blocks. I can't see why it wouldn't fit.
  5. Robert m
    Robert m Addict
    Apple Valley, Ca
    '94 single cab, 22re, 5spd
    it will probably fit without too many issues but passing smog is going to suck.
  6. standardbyker88
    I think on that, you'd just wanna keep the smog systems from the newer motor to replace the systems the truck had. Or get an older truck like I plan lol.
  7. White Trash
    I don't think there is any way to do that swap legally in commifornia. Smog oaws are complete and utter bull**** since there is more to it than a sniffer test. That right there tells you its about money.
  8. standardbyker88
    I know they have underhood inspections and comp scans too. But 75 and older is exempt. And I read somewhere that you can transplant a newer motor system in if retaining original emissions systems to that engine. But I can't recall if that applies to Cali as well
    When/if I move there, I'm diesel swapping my dodge and getting an older Toyota. That will solve my issues.
  9. White Trash
    Western WA sucks so bad it makes people want to move to a communist state. :lol:
    As far as I know in CA you can't swap engines between manufacturers since the engine has to have been available in the newer model of vehicle its going into. Such as when Marlins son Big Mike swapped a 3rz into his 83 it was legal since it was a natural progression. And yes all factory smog garbage had to be retained.
  10. standardbyker88
    Again, if I go I'm getting an older truck lol. Back on point, it would be a cool swap to do. Making the power stick to the street migh be tough without wide tires.
  11. 87pickup
    87pickup Member
    ontario ca
    Well I figure might as well go IRS
  12. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    I don't think swapping between manufacturers is a problem as long as you have the COMPLETE smog equipment from the newer vehicle; lots of SB Chevies and Fords end up in places they don't belong.
    But swapping between vehicle types is not allowed. That is, you can't put an engine that came out of a car in a truck or the other way around.
    As someone said, the smog laws are a lot of BS; read up on all the smog laws if you plan to try and do it legally...
  13. yota4life
    Im swapping a diesel in mine as we speak. An irs would be a good idea an maybe something to add a little weight to the back
  14. 87pickup
    87pickup Member
    ontario ca
    So another question is can you go from high compression pistons to low compression???
  15. 87pickup
    87pickup Member
    ontario ca
    Well If I do go through with it i don't think I will try and make it smog legal their is no point
  16. 87pickup
    87pickup Member
    ontario ca
    Well for the weight part I'll just put a bed cover
