Pinch or Rockers??????
Discussion in 'Suspension/Chassis' started by Lotoy, Jul 17, 2013.
  1. Lotoy
    Lotoy Enthusiast
    knoxville tn
    92 std cab
    :shrug:I'm can't decide, i was all about rocker but I don't wont to hack up the pinch any suggestions?
  2. Lotoy
    Lotoy Enthusiast
    knoxville tn
    92 std cab
    Pinch or rocker
    It should lay rocker
  3. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    You already bodied it but I planning on shortening the frame under the cab and laying the pinch weld. I am not trying to be the lowest, just the cleanest. Litneon and another guy from Japan are on the top of my List... If you want to enter some limbo contests then go to the rocker. If not stay at the pinch weld.
  4. TRUCK ACTION
    Too lay completely on the rocker you will have to shave the pinch!
    I'm not bodied but did shave the pinch,as didn't like the look of the pinch sticking down when laid out!!:cool:
  5. yota4life
    Itll look better laying flat rocker. Pinch doesn't look right.
  6. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    True that. You dont have to cut it off. You can use channel locks to get it bent, then use a heavy hammer to bend it back and flat against the cab. Its what I did...and yes, it looks way better laying rocker.
  7. Xs5875
    Xs5875 Addict
    Greenville, Ga
    Pinch/Rocker
    My buddies on the pinch..
    Mine on the rocker..
  8. raylcc
    raylcc Addict
    Denver, CO
    I would say to build the bottom six inches or so of the truck to extend and collapse like one of those folding cups that were popular in the 80's. That way when you lay it out, the panels fold up into themselves, giving the impression that its laying out UNDER ground level.
  9. Xs5875
    Xs5875 Addict
    Greenville, Ga
    :doah:
  10. Lotoy
    Lotoy Enthusiast
    knoxville tn
    92 std cab
    :bow:
  11. Lotoy
    Lotoy Enthusiast
    knoxville tn
    92 std cab
    The only thing I don't like about the pinch is the gap at the bed where there is no pinch! Do u guys cut it off or fold it over
  12. Xs5875
    Xs5875 Addict
    Greenville, Ga
  13. Xs5875
    Xs5875 Addict
    Greenville, Ga
    Oh and hey I got the armrests today....thanks.
  14. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    cut it back until you lay hood
  15. burnzya
    i hate the look of the pinch hanging down. it's usually a rough piece from the way the inner and outer weld together, and nobody seems to smooth em out before paint.
    but i'm also not a fan of rubbing a piece of sheetmetal against the pavement.
    i shaved my pinch weld off. was a pain in the butt being an older truck it was a little dirty. but i also bodied mine leaving about 1/4" of space between the ground and the rocker.
    i ride pretty low and frequently bottom out going down the highway at 75 mph. but the rockers have yet to catch.
  16. Lotoy
    Lotoy Enthusiast
    knoxville tn
    92 std cab
    Laying rocker
    Well you guys where right it does look way better on the rocker
  17. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    :funnyup: Staying @ the pinch is like winning the special olympics...
  18. Bigt
    Bigt Newbie
    North Mississippi
    89 std cab
    can i lay 20s on rockers without havin to cut the hood?
  19. Xs5875
    Xs5875 Addict
    Greenville, Ga
    Yes. Run a 30 series tire.
  20. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    Yup. Thats what I run.
