HELP..engine oil leaking into the combustion camber
Discussion in 'Engine/Drivetrain' started by enjoi121, Oct 1, 2013.
  1. enjoi121
    enjoi121 Newbie
    ohau, waipahu
    93 single cab
    when i was doing a tune up. taking out the spark plug, the plug had engine oil on it. so i was thinking engine oil leaking into the combustion camber. when driving, rpm drop once in great while. i know engine messing up my ignition system. i want to know how to fix this problem or suggestion what to do???
    i have 22re motor....
  2. SD YOTA
    either your valve stem seals are in need of replacement, or your rings are bypassing oil.
    does your truck smoke first thing in the morning on a cold start and go away as it warms up? or does it smoke all the time? does it smoke heavy when you get on it?
  3. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    Compression test will give you an answer.
  4. enjoi121
    enjoi121 Newbie
    ohau, waipahu
    93 single cab
    @sd yota smoke in the morning then goes away.
    @malesohomegrown compression test ill try it, let you know how it goes.
    today my motor die out in middle of the road. it took me awhile to start it up. i think that i not getting spark.
  5. SD YOTA
    yer probably oil fouling the plugs. as homegrown said, do a comp test and see whats going on.
    if it smokes in the morning your valve stem seals are likely leaking. the comp test will let you know if yer rings are done though...
  6. enjoi121
    enjoi121 Newbie
    ohau, waipahu
    93 single cab
    I found out my msd box wasn't working so I wasn't getting any spark to my plug. So I change everything to oem. Everything work fine for now.
    But I need to reinstall my tach but I don't know where the green wire go to. Any pictures will help me a lot.
  7. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    run the tach to the Ig- pin on the diagnostics connector.
