Fuel squirting out back of injector?...
Discussion in 'Engine/Drivetrain' started by DumpsterToy, Sep 25, 2013.
  1. DumpsterToy
    DumpsterToy Member
    Rancho cucamonga
    93 single cab
    So i have the fuel rail torqed down to where it needs to be and it seems like my injectors have a little play in them. I always inagined that they should be in there tight?... When i turn it overbit shoots fuel out the back or one and two? Has this happened to anyone else?...
  2. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    They should not have play.Check your o-rings on the injectors.they should pop down in there like spark plug boots.Also make sure all your banjo bolts have that copper o-ring on them.They are easy to loose and hard to replace.
  3. Malessohomegrown
    Malesso,Guam
    I think you should try to pin point exactly where the fuel is squirting from first.
  4. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    When properly installed the fuel injectors can be rotated rather easily by hand...out the back is a vague description.
  5. DumpsterToy
    DumpsterToy Member
    Rancho cucamonga
    93 single cab
    The back i meant the side that goes into the fuel rail sorry. And i got it fixed it was bad o rings. Another question i had is theres four sensors on top of the valve cover, they have some vacuum lines running to them. Im missing the sensor closest to the front of the car. Can you tell me what its purpose is and the affects of not having it. My trucks idle is all over the place and im wondering if that could be the cause...
  6. Malessohomegrown
    Malesso,Guam
    yes that could be one cause of your idle issues.Take a picture so we know which one you are talking about.Here's a reference pic[​IMG]
    This is a 92 so yours could be slightly different.
  7. DumpsterToy
    DumpsterToy Member
    Rancho cucamonga
    93 single cab
    That pictures perfect. If you follow the letters on the valve cover, after toyo you come to the metal plate. That first grey plug is whats missing. Any idea what thats for? Ive been using a haynes manuel and i wish i could get my money back to say the least lmao
  8. Malessohomegrown
    Malesso,Guam
    grey plug:AC fast idle.If no ac you dont need it just at the manifold(just below the big black screw with the spring)route the vacuume line back to itself like a U.
  9. Litneon
    Or cap them both off. It sounds like you have a vacuum leak for sure. If that doesn't fix the idle, run through the rest of the vacuum lines and check for cracking or other missing components.
  10. DumpsterToy
    DumpsterToy Member
    Rancho cucamonga
    93 single cab
    Sounds great ill do that today. Thank you very much!!
  11. DumpsterToy
    DumpsterToy Member
    Rancho cucamonga
    93 single cab
    Ok so my assumption came down to, all hoses are connected an ok looking, when my ar starts up at high idle its fine then wen it warms up it tries to down idle and deops way under, i smelt something funny and my ass started getting hot, look under my cab and my catalytic converter is glowing red like glass on a blow torch. Im going to replace the car and im hoping thats the last downfall to my running issues so i can finally start on the looks of my beast...
  12. standardbyker88
    Bad cat will surely throw off the idle. Especially after it warms up and the cat is glowing. Air can't move through obviously, so it gets hot. Hope you figure the issues out.
    As for the brass washers, they can be replaced. Often the 100 piece brass washer kit is te best route instead of buying a bunch for the same price.
  13. IronNam
    get new o-rings for those injectors yet?
