Looking for a set of 15" steel wheels for a '93 2wd Pickup... ... can anyone tell me where to get a set that fits? Is there a forum vendor here that sells 'em?
I located some 15" steel wheels that I like --- they are 15x7" with 4.5" backspacing, or +13mm offset --- will these fit a normal 2wd Pickup if I use factory-sized (stock diameter) tires? Still tuck pretty well or will they be close to the fender lips...?
Any further info here, guys? Can I run 15x7" with 4" backspacing? How about 3.5" backspacing on 15x7"?
should run just fine. a 7" wide wheel is a pretty conservative size on our generation trucks. the fender wells are fairly big. im running a 185/60/14 on mine so they fit fairly well. no rubbing. mind you, the truck is also fairly slammed.
