What does it mean when the Charge/Brake light come on
Discussion in 'Engine/Drivetrain' started by Hinudie, Aug 19, 2013.
  1. Hinudie
    Hinudie Member
    North Hollywood, CA
    87 Toyota Pickup
    Charge/Brake light came on last night and stayed on all today..... Does anybody know what that means?
    Thanks!
    Ronnie
  2. burnzya
    on these trucks it's usually an indicator that your alt is going to die soon. never hurts to check grounds and battery/alt connections too.
    TRUCK ACTION likes this.
  3. Hinudie
    Hinudie Member
    North Hollywood, CA
    87 Toyota Pickup
    That's weird bc I just replaced it a few months ago..... Pretty much brand new
  4. Scomber
    Scomber Enthusiast
    Down East
    I'll second what burnzya just said. I had a spare alternator from my parts truck when it happened to me a few months ago. That made it all better. Maybe it is a bad connection. Uninstall and reinstall. See if that helps. But be prepared for the idea that you may need to get a new one soon.
  5. Madness
    Madness Enthusiast
    Westminster, Co
    I've had an alt die within a few weeks. Most of the ones you buy at the local parts stores are refurbished. Someone could have missed something when putting it back together. Safe bet is to pull it out and take it to a parts store to have it tested. Most if not all have a lifetime warranty.
  6. atc70
    atc70 Newbie
    INDIANAPOLIS
    1985 22ret, 1988 4runner
    it could also be low brake fluid:waytogo:
  7. Kev55
    Kev55 Enthusiast
    florida
    when my alternator died, I never got a light.
    when my brake fluid was low, I got the light.
    But I agree, double-check the connections anyways
  8. riceratyota
    riceratyota Veteran
    backwoods oklahoma
    which one 77/78/79/81[r.i.p]82 sbrc driftbox, and a CeliLux/current daily= 79 sbrc [lil' blue]
    white red wire at battery, alt. ground loose/rusty alt plug wire broken just outside the connector [just had that one happen] regulator failing just start tracing powers and grounds and you find it soon
  9. Hinudie
    Hinudie Member
    North Hollywood, CA
    87 Toyota Pickup
    Thanks guys!! Just said F it and changed the alt (what a b#tch) and it seems to be good now!! Bad Alt it was...
    Thanks again!
  10. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    yeah alternators can be a bitch with that tight fitting bracket.I always take a grinder to my alternator and shave a little off those bolt spacer things and it makes it way easier to slide that bolt in.
  11. BaggedYota90
    BaggedYota90 Member
    Lewiston, Idaho
    1987 4Runner
    Ya some auto part stores sell some iffy refurbished parts, but sometimes nice cause they offer a decent warranty. I just had to replace my 6 month old alternator on my 4Runner last week. Had the old Brake and Charge light pop on at about 6000 RPM's, completely toast. Plus side is it was free thanks to that warranty and took only 10mins to replace. :clapping:
  12. 93TILinfinity
    93TILinfinity Veteran
    Lake Elsinore, CA
    1993 Toyota pickup 2wd 4cyl 5speed cab and a half standard bed
    I didnt want to start a new thread and im having a similar issue. My parking brake light stays on even after its not in use. I have to press down on the brake pedals preaty hard for them to function. I checked the fluid and its not empty. What can it be?
  13. jetas
    Master cylinder? Bad vacumm to the booster.
  14. 93TILinfinity
    Lake Elsinore, CA
    Idk I'm hoping that it just need to be bled or something. If not then ill have to look into the cylinder and vacuum
  15. jetas
    I think a bad vacumm would make the engine run wierd
  16. Andy323
    Andy323 Newbie
    I have the light problem too when I turn on my headlights which are custom Morimoto projectors but I have driven with the lights on for about 30 mins and no signs of my truck wanting to turn off
  17. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    That sounds like a different problem, what exactly is it doing?
