Marker/signal combo
Discussion in 'Exterior/Body' started by yota89, Jun 13, 2013.
  1. yota89
    yota89 Enthusiast
    guam
    89 single cab
    Yo guys I was just wondering has anyone done a
    marker light signal combo?
  2. Robert m
    Robert m Addict
    Apple Valley, Ca
    '94 single cab, 22re, 5spd
  3. OUTLAWEDCONCEPTS
    OUTLAWEDCONCEPTS Member
    BLAIRSTOWN,NJ
    74 HILUX,84 XCAB,94 XCAB
    I did it in my 84 ive heard its alot easier in an 89-95 body style go to the auto parts store they sell i think theyre 1159 bulb pigtails its a gm double filament bulb style and you can un hook the blinker harness and bring it up thru the fender to the marker light.
    Since i have an 84 i have less room i used a piece of pvc and plastic welded it to the inside so i could fit the bulb i used the threaded one so the teeth on the bulb socket had something to hold it from popping out.
    Hope that helps if you need pics i could probably post some up
  4. geonbugman
    geonbugman Member
    Columbus
    93 Pick-up
    Wait don't make any more holes, you can use the stock bulb and tie into your bumber light + to make them alternate. I'll have to find it when I get home.
  5. yota89
    yota89 Enthusiast
    guam
    89 single cab
    Show them pics
  6. geonbugman
    geonbugman Member
    Columbus
    93 Pick-up
    wire the side marker ground wire to the parking light hot.
    http://www.painlesswiring.com/Manuals/20112.pdf
    I know it sounds crazy but the light will seek a ground and when both sides have positive the light turns off. I wish I had my side markers still I would post the pics of what I did.
    Learned this back when My brother put a harness in his Camaro.
  7. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    Yes, a number of cars were wired from the factory like that, late 80s/90s domestics i think. I'll. Just run the ground of one bulb to the + side of the other. the parking lights ground through the turn signals but limit the current below what turns them on.
    I will qualify this in that I did this from memory+electrical knowledge NOT experimentation on my truck. The numbers match up but I have not tested it.
    The result is:
    Parking lights on/turns off: parking lights on
    parking lights off/turns on: turn+parking lights flash
    parking lights on/turns on: park & turn lights alternate.
  8. IronNam
    Get a socket with three contacts with matching bulbs, might as well order LED's.
    Ground and Parking lights run to the "low" contacts, turn signal into the high contact.
    Boom, done.
