2wd to 4wd
Discussion in 'Suspension/Chassis' started by evansdmax, Jul 25, 2013.
  1. evansdmax
    evansdmax Member
    I have my 94 pickup and just bought a rolled 4wd frame and all suspension seems fine but body and interior is shot. Are the frames the same or should I just put my body it its frame. Are the bodies all the same how easy r hard is it gonna be?
  2. White Trash
    The only difference in the body is there is no hole for the t case shifter and the front fenders have a flare so the marker lights are different. Otherwise it's all the same stuff.
  3. evansdmax
    evansdmax Member
    Ok sweet... My frame actually is in a lot better shape are they the same or does the 2wd frame have all the holes to mount all the 4wd suspension? How bad is the wiring to switch bodies? Hoot thing is I have good runnin gear for both 2&4 wd trucks 2 good motors all for less than 3 grand
  4. burnzya
    2 and 4wd frames are completely different in the front.
  5. evansdmax
    evansdmax Member
    Alright man that sucks!!! I wih it was like a newer chevy they are exactly the same!! Well looks like ill be takin the body off.... Cleaning and sand blasting and puttin my nice body on that frame!!! Sounds like a could good long weekends
  6. White Trash
    Yes the frames are different but the body is the same ergo a 2x body will in fact bolt right onto a 4x chassis.
    Depending on year there may not be much wiring needing to be changed or there may be a whole harness swap. It's actually simple to swap the harnesses if needed, the dash harness is the hardest one to swap and even it is easy just time consuming.
  7. evansdmax
    evansdmax Member
    They are both 1994 models I will have them sitting side by side when I do the swap both 22re trucks with air. I couldn't have gotten luckier on the purchase I don't guess. I plan to sell the left over parts from the 2wd when it's all finished that I won't be able to keep for spare on my new 4wd truck it only has 114k miles how much you think I can get for the rolling chassi minus motor and body?
  8. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    Unless ya got a 4runner....lol.
  9. burnzya
    a 2wd 4runner shares the same frame as the 4x4, they just left out the front drive stuff and transfer case.
  10. evansdmax
    evansdmax Member
    Well I have changed my mind. What's a good 4wd running gear worth the bed is in ok shape a little rust but body and interior is shot!! I'm gonna take the motor for a spare for my 2wd and part out the rest!! Anybody need anything or whole truck ill sell it
  11. evansdmax
    evansdmax Member
    Will the motor trans combo got in a 92 4runner with ease or is it a pain? Are the ifs and the rear diff the same in truck and runner? Maybe have a 4 runner donner body and good frame had te 3.0 in it with a auto
  12. Xs5875
    Xs5875 Addict
    Greenville, Ga
  13. evansdmax
    evansdmax Member
    Well I might have a 92 4 runner do you know if the motor 5speed and transfer case will bolt in it without to much work?
  14. White Trash
    Motor mounts on the frame are different, runner rear axle housing is the same width but has mounts for links, coils and pan hard built in.
  15. evansdmax
    evansdmax Member
    But can you get motor mounts? Will it bolt up to the factory auto trans in the runner
  16. evansdmax
    evansdmax Member
    bump ttt anyone done this swap? would the 22re engine trans and transfer case bolt into the 4 runner? or just the engine bolt up to the 4 runner automatic trans?
