blocks
Discussion in 'Suspension/Chassis' started by -85yota, Jul 7, 2013.
  1. -85yota
    -85yota Member
    i just placed a order for 1 inch block i already have a 3 inch block. my question is how do i put the blocks the 3 on top or bottom or it dont matter...??? :thinking:
  2. standardbyker88
    I've never heard much about stacking blocks. I would say to run the bigger one on the bottom. When I had 4" blocks the top side walls cracked. I got new ones and the same thing happened. So I cut them down to 2-1/4" each and drilled completely through them. Used a 6" long grade 8 3/8" bolt thru both blocks and the leaf pack. Zero movement even without the u bolts. Might be an option to consider just to be safe. I also had new u bolts made at a 4x4 shop. Used the biggest rod that would fit thru my base plate holes. Never had any issues after that. I drive hard and have a built 20/22r motor. Hope this helps.
  3. White Trash
    Stacking blocks is hacktacular at best. Just order up some new ones or hit autozone.
  4. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    3-inch drop leafs and a 1-inch block is what i'd be looking into if I were going that route. It's a good excuse to replace bushings while you're at it.
    I like the idea of the bolt through everything, standardbyker. Hadn't thought of that for keeping everything safe.
  5. standardbyker88
    Mine started as DJM (dangerous junk metal) blocks. The aluminum style. They are a hollow top style. The walls busted off. I refuse to ever buy aluminum blocks again. I will run solid steel ones anytime I block stuff from now on. But it was the best cure I could think of. With just the long leaf and overload if dropped the back to almost the frame. That's been my rear combo for a few years now.
  6. yankeetaco72
    yankeetaco72 Veteran
    Escondido
    82 short /97 Tacoma
    Never, never stack blocks that situation is no bueno..
  7. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    ^^x2
    just spend the money and order 4in angled blocks, you start to get driveline vibes at 4in anyway.
  8. lowplz
    lowplz Member
    Hayward, CA
    87 longbed
    run a five inch block like me lol
