cali weather is killing my truck!
Discussion in 'Engine/Drivetrain' started by rida4christ, Jun 29, 2013.
  1. rida4christ
    rida4christ Member
    Hesperia CA
    Before my truck would act up after long use and being hot but not overheatting. And now at 103º its acting up in mid drive does the efi have a choke system? Cause that's whatmI'm suspecting.
  2. SD YOTA
    by "act up" what do you mean? does it run hot? overheating? poor performance as in acceleration? poor idle? be specific...
  3. rida4christ
    rida4christ Member
    Hesperia CA
    Ooohh yes sorry, I mean poor idle and accelaration and I start getting smoke and smells like fuel.
  4. IronNam
    How's the maintenance on the truck?
  5. rida4christ
    rida4christ Member
    Hesperia CA
    Resent plugs , oils getting a lil dark, I do have a code 27 wich is the second o2 sensor but that's it.
  6. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    I bet its because your efi doesn't know the air is thinner because its hot, so it's not adjusting the fuel to be less.. Basically running rich because the mixture is off..
    Your o2 sensor is probably causing it.
  7. IronNam
    rockauto.com
    find the part number for the O2 sensor and then find the denso part on rockauto.
  8. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    First you need to get the o2 fixed the first generations and examples Efi are not exactly top notch
    Older Efi systems don't have large parameters of fuel and timing you factor in a bad o2 sensor and extreme heat ... especially with modern ethanol fuels . The dead sensor can't communicate with the air/fuel and timing trims
  9. rida4christ
    rida4christ Member
    Hesperia CA
    You peeps are freaking awesome! !!! I'll will check that out.
  10. rida4christ
    rida4christ Member
    Hesperia CA
    Can the o2 sensor even prevent the truck to start? Cause that's what it's doing. It hesitates to start.
  11. SD YOTA
    there ya go brother...
    start by replacing that sensor and report back in from there.
  12. IronNam
    and a can of B-12 chemtool in the gas tank to let that stuff clean out your fuel system and injectors. trust me.
  13. rida4christ
    rida4christ Member
    Hesperia CA
    Ill try it thanx
  14. rida4christ
    rida4christ Member
    Hesperia CA
    I'm checking rockauto.com and its giving me 4 different denso part #s wich one is it
  15. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Rock auto has some good prices no lie about that but compare your local parts store denso price vs ordering one..........get it local return it local or compare old to new right at the parts counter ..just my two cents
  16. standardbyker88
    Also if you have a brass radiator swap to aluminum. Exchanges the heat better. Lower temp thermostat helps let the heat out of the block earlier too.
  17. IronNam
    I got the parts number from the Toyota dealership (call them up) and then use that to find the matching one on Rockauto.
    Toyota wanted $180 for the denso.
    I got it for $60 on Rockauto, same exact part, plug and play. (perfectly)
    and no problems since. It's also a Denso, not some pos Bosch.
  18. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Retract my previous statement I looked at autozone web page they want 100 bucks for a denso o2 rock has them for 60 ..so that's a no go .just do what cinnamon said get the part number and have at it
  19. IronNam
    just looking out for you guys.
    When Toyota told me they wanted $180, I set out to find something much much cheaper. :D
  20. TRUCK ACTION
    If you have a code showing a problem----------------FIX IT!!!
    Secondly any thing effecting the fuel system( O2 sensor ),will effect the running of your truck!!!:cool:
