I have a set of Factory steel wheels off of a XJ Jeep Cherokee that look like the factory 14" steelies on my 79 2WD but are 15x7 and have a 5.25 backspacing but the same 5 on 4.5"/114.3mm bolt pattern. Has anyone used these or other factory wheels from other manufacturers?
Just got some silver mesh with same specs. they fit and clear. Just got to put longer bolts on hub. The hub size is 71.5. Not sure if they lug centric or hub centric. Still thinking what I want to do. Will post some pics up later.
