Longer wheel studs
Discussion in 'Suspension/Chassis' started by Joe049, Apr 27, 2013.
  1. Joe049
    Joe049 Member
    Las Cruces, NM
    94 Pickup
    I recently got 3/4 inch spacers for the rear of my truck but the studs only stick out about a 1/4 inch.. I've looked around for longer studs and the Lexus is300's studs seem like they'd work because they have the same knurl size and thread size, but I'm still not sure and I don't want to order anything that is the wrong fit. Anyone know if they'll work?
    Here is the link to the studs http://www.summitracing.com/parts/arp-100-7715
  2. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
  3. Robert m
    Robert m Addict
    Apple Valley, Ca
    '94 single cab, 22re, 5spd
    ARP# 100-7715 is for the is300 studs
  4. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    almost all toyota cars use the same studs. Or at least the same replacement studs per dorman.
    The ones listed for the 4wd rear are the listed (by dorman, whos book I was looking through for reference) longer stud for 2wd applications. Albeit only about 1/4" longer.
    If A=B and B=C then A=C aftermarket extended studs for most toyota cars should fit. Don't quote me I haven't tried it.
  5. MilehighHilux
    MilehighHilux Enthusiast
    Honda extended studs also work
  6. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    they "work" or are they the same size and are interchangeable according to the book? I wouldn't be surprised if they were but want to make sure.
