where to find a good H/O alt?
Discussion in 'Interior/Electronics' started by DannyBoy, Apr 27, 2013.
  1. DannyBoy
    DannyBoy Enthusiast
    Tacoma, WA
    91 xcab
    i need a good one that i can replace the stock one with.
  2. Robert m
    Robert m Addict
    Apple Valley, Ca
    '94 single cab, 22re, 5spd
    how many amps you looking for? there is a 120 amp alt on ebay for pretty cheap.
  3. TRUCK ACTION
    Read my post on this subject, I went to a GM 3-wire,150 amp,00amp @ idle!!:cool:
  4. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Common Toyota swap is to switch to a gm alternator most of them produce high amps at idle and bracket swaps are available and or I believe a later style 22r alt bracket will work there's some info on the web about this gm alts are everywhere and considerably cheap. And truck action beat me to it ^^^
  5. topcop182
    topcop182 Addict
    Colorado Springs Colorado
    1993 single cab 2wd
    check lce engineering
  6. icpurplepplalot
    icpurplepplalot Member
    Baton Rouge
    94 Base
    Look up tenney alternators if you want something bigger than the gm 3 wire.
  7. DannyBoy
    DannyBoy Enthusiast
    Tacoma, WA
    91 xcab
    i'm going to be running around 3000w with just the subs when im done, as well as a fold-down screen and a second battery. will the GM 3wire be able to handle that?
  8. NotAvailable
    NotAvailable Addict
    I would run. 2 batteries group 31s. And you could always get a higher amperage 3wire alt also. My stock alt has the big three and 1 group 31. Im only running total 1000atts with my highs amp and sub amp (smaller system.) My voltage drop isnt too bad. Keep the revs up and your good.
  9. williyumz
    williyumz Enthusiast
  10. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Good info ^^ had no idea jag alts would fit ....if your into high watt sound systems . Might consider a gm powerbastards.com 220amp alt and the above mentioned battery's and upgraded cables or get crazy and run two alts like the pro sound guys
