no fuel in carb bowl
Discussion in 'Engine/Drivetrain' started by jaydnky85, Apr 15, 2013.
  1. jaydnky85
    jaydnky85 Newbie
    Los Angeles
    85xcab
    Hey guys I recently did a 22r Rebuild and now that everything is in place there is no fuel traveling into my carburetor. The carburetor is the original Aisin rebuilt and the Mechanical fuel pump is new. Any ideas on what my problem is? Thanks
  2. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    Are you getting fuel thru the line going to the carb?Check that first.If you are the the float bowl is probably getting stuck.Maybe when you rebuilt is sat for a while dried up and got stuck.You gotta open up that window and finger it loose or try tapping on the carb with a hammer right on top of the FB.Just remember with the mech. pump you gotta crank over to get fuel not just key on.(sorry if that was like stupidly obvious but just making sure)
  3. jaydnky85
    jaydnky85 Newbie
    Los Angeles
    85xcab
    Thanks, also none of the fuel lines have gas and my tank is half full
  4. Malessohomegrown
    Malesso,Guam
    Ok so it's not the carb then.Start at the new fuel pump.Pull the pick up line going into the tank and have somebody crank and you should be getting suction from the fuel pump.
  5. jaydnky85
    jaydnky85 Newbie
    Los Angeles
    85xcab
    Thanks ill give it a try
  6. Malessohomegrown
    Malesso,Guam
    Before you rebuilt was the truck mechanical fuel pump?
  7. jaydnky85
    jaydnky85 Newbie
    Los Angeles
    85xcab
    Yea it was
  8. Malessohomegrown
    Malesso,Guam
    Did you guys have to touch any of the lines from the fuel pump back?
  9. jaydnky85
    jaydnky85 Newbie
    Los Angeles
    85xcab
    yea the lines that lead into the carb in the rear
  10. burnzya
    i usually pour a little gas down the carb to get the motor running and that will make it prime the lines and get fuel.
    but i'm not sure if thats a good idea for 1st start on a rebuild.
    i've also pressurized my fuel tank with compressed air to help push fuel through the fuel system.
  11. jaydnky85
    jaydnky85 Newbie
    Los Angeles
    85xcab
    @burnzya thanks for the info ill give it a try
  12. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    If it has set for a Long time or the fuel system has drained creates a cavitation in the system the stock pump has trouble pulling from that far with empty return lines . Back pressure affect had this same problem while I did my motor . I used starter fluid and let it run on that for about a minute until the pump finally created a syphon effect The air trick works to
  13. jaydnky85
    jaydnky85 Newbie
    Los Angeles
    85xcab
    @scrub88 i tried the starter fluid but no luck how do i get compressed air in the tank?
  14. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    You sprayed starter fluid down the barrel of the carb and it didn't crank . At all that bypasses the carburetor . It should of fired off u have spark right ?
    Stick a air nozzle on the end of the return line and blow air or stick it n the fuel neck and wrap a rag around it help seal .. I've done that a few times on older vw
  15. Malessohomegrown
    Malesso,Guam
    Dude try pouring straight up gas into the carb.not too much like 2 or 3 cap fulls.But like scrub88 says make sure you got spark first.
  16. jaydnky85
    jaydnky85 Newbie
    Los Angeles
    85xcab
    It stays on as long as it has starter fluid but as soon as it burns that it shuts off i think the fuel lines are sucking in air im going to try and replace those today Thanks for the help
  17. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    O okay I got ya a simple test to check fuel line condition . Small bucket and some fuel line of the same size as stock and run them from the bucket to the pump hooked up just like it would be from the factory
    You'll be able to see it pumping and returning fuel .. This will rule out everything but the tank and oem lines . Before u go under and start pulling lines and replacing .
