lowering blocks
Discussion in 'Suspension/Chassis' started by shai, Apr 10, 2013.
  1. shai
    shai Newbie
    sunshine coast
    00 single cab hilux
    I have a 2000 hilux with reset leafs and 3inch blocks.
    Im just wondering if anyone has 4 or 5 inch blocks.
    The diff is sitting about 2inchs from the chassis, i wanna make the diff and chassis touch.
    If anyone can help me would be greatfull :)
  2. Byronics
    Byronics Veteran
    Hilo, Hawaii
    89' Single cab
    this guy makes good blocks BLOCKS 5" / 1/2" GRADE 5 U-BOLTS
    i'm not sure about making the diff hit the frame though. the sound of it hitting everytime you hit a bump in the road gets irritating. maybe a baby notch would be good if you wanna go that low.
  3. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    X2 on the rear axle resting on the frame . You'll eventually bend your axle tubes from constant abuse not to mention the back shattering ride
  4. shai
    shai Newbie
    sunshine coast
    00 single cab hilux
    I was thinking of notching, it would be a better solution.
    The banging dosent faze me.
    How much would notching cost and how long would it take to do?
    i use my car everyday for work and that
  5. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    Not a good idea for a daily banging the rear end... And there's no 2000 hilux.
  6. Beefed Taco
    Beefed Taco Addict
    Simple c-notch will restore the ride. There's no need to suffer the embarrassment of a truck that has zero suspension.
