trans coming outta gear!
Discussion in 'Engine/Drivetrain' started by estgang1991, Apr 7, 2013.
  1. estgang1991
    estgang1991 Enthusiast
    oklahoma city, oklahoma
    '89 hilux
    ok, so i just put a new clutch kit in my truck toady, just OE though. now my trans is popping outta first gear and outta 3rd too? :mad:what's the deal here!? fix one thing then something else goes wrong. broke my damn hand working on this thing today, now i just wanna smash it into a telephone pole. :brickknock:
    please... help me...
  2. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    Probably the shifter bushing is worn.It's the little cap bushing that goes on the ball end at the bottom of your shifter.Like $7 but gotta get them at the dealer.2 bushings i believe.
  3. IBeSeeN
    IBeSeeN Addict
    Harrisburg, Oregon
    89 Toyota
  4. IronNam
    I got my white bushing from marlin crawler. It's solid and won't wear like the OEM ones. When I got my W58, the bushing was pretty much non-existant.
  5. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    Nope. Trans synchronizers are worn. I had a '82 that did same thing except it was 5th gear only. I cool hold it in there, but as soon as I let it go and gave it some gas...popped right out. Need a new trans. Or yours rebuilt.
  6. estgang1991
    '89 hilux
    the trans was rebuilt less than 6 months ago!! i have reciepts! EFF that!!! why did it just start when i changed my clutch?? that's the question i asked. it was perfect before yesterday.:mad:
  7. riceratyota
    riceratyota Veteran
    backwoods oklahoma
    which one 77/78/79/81[r.i.p]82 sbrc driftbox, and a CeliLux/current daily= 79 sbrc [lil' blue]
    more power into trans from fresh clutch puts more load on it did your grind any gears with the worn clutch?
    syncs. could be bad but being 1st + 3rd bushings the likely culprit
  8. estgang1991
    '89 hilux
    naw man, i drive my truck hella carefully actually, i try to take care of it. i'm not sure but i may have damaged the bushing, idk i haven't looked at it yet really. it just pissed me off and i didn't wanna mess with it anymore.
  9. riceratyota
    riceratyota Veteran
    backwoods oklahoma
    you took the shifter out to change the clutch you could have lost the bushing
  10. riceratyota
    riceratyota Veteran
    backwoods oklahoma
    i have a homemade one make it out of a piece of motorcycle handle bar about 1/2 in long with a couple of plastic sleeves [made from the little red plugs you get on a salvage motor]on the inside and outside of the tubing works well, its cheap[free], and can be replaced in no time if my redneck repair fails
  11. estgang1991
    '89 hilux
    naw, i ain't remove the shifter from the trans. actually i couldn't get it off! i know the bushing is still on the shifter handle i think it's just wadded up in one of the other rubber boots off the shifter. i'ma try that when i get outta class today and see if it helps. hopefully it does. THANKS!!
  12. estgang1991
    '89 hilux
    i got that part of it fixed, i just didn't have the rubber boots that go around the shifter back in place right and it just had enough pressure pushing on it to pop the trans outta gear. perfect now though
