89 control arms on a 93
Discussion in 'Suspension/Chassis' started by DionTDE, Apr 1, 2013.
  1. DionTDE
    DionTDE Addict
    Preston, ID
    93 single cab 2wd
    Ok so i have tried to start this thread 3 times already from my phone. I guess it doesnt work.
    I found a friend that has a set of lower control arms with bag mounts from an 89. Is there any reason why they would not fit on my 93?
  2. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    All 89-95 trucks are the same.
  3. patrickgraven
    patrickgraven Veteran
    Corona CA
    nope no reason. The 89-95 are the same, the 84 to 88 are also the same. The only difference between them is the lower ball joint mounting holes. But they are all the same.
  4. DionTDE
    DionTDE Addict
    Preston, ID
    93 single cab 2wd
    That is exactly what i thought! I will pick them
